AH FabricationsChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Ian2012
Thread: 1.9 tdi 130 no power when cold
    Oct 2012
    434
    I have posted this in the A3 8 L section but i as this engine crosses into B6 would your advice too. Basically when the car is stone cold it has no real power like the turbo isn't working, then after 2 or 3 miles bang it's all ok, no codes at all vcds?
    What gives?
    Ian
    Oct 2009
    Hull
    1,442
    could be the oil viscosity been too thick not allowing the turbo to spool up properly
    mine is a bit sluggish for a mile or so if its really cold
    have you got the right grade of oil in too?
    Oct 2012
    434
    Don't know to be honest it's due a service now and i have only just bought it, my other 1.9 engined car doesn't suffer from this!
    Oct 2009
    Hull
    1,442
    Give it a service and see what its like after it
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    To be fair engines need nursing from cold, I wouldnt be trying to make any real power before it has warmed up.
    On my old Ibiza Cupra (1.8T) boost and fueling was limited before it hit a certain temperature - it may be the same case here?
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Oct 2012
    434
    Interesting idea i will see what it's like today, i am going to try Mr Muscle turbo clean as well to see if that will make any difference.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    I would give it a full service and also change the fuel filter
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Nov 2013
    101
    mine is a bit like this sometimes. only had it a few weeks so though it was normal. but as it's been frosty for the last few mornings i start it 5 mins before i need to leave and it's been fine.
    B6 A4 Avant 1.9TDI Sport 130
    YSN
    YSN's Avatar
    Sep 2013
    93
    My B6 is similar, when it's totally cold in the morning shifting gears is also a bit stiff so just drive gently for a while until the engine has had a little stretch. But I would suggest maybe you check your engine oil have you had a recent oil service or anything or has this problem just started?
    Oct 2012
    434
    I have only just bought it, i will give it a full service tomorrow see what happens then
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Don't forget the fuel filter for peace of mind
    Mike
    - BUILD THREAD >>
    Oct 2012
    434
    it's gonna be replaced tomorrow
    Oct 2012
    434
    The Mr Muscle clean has so far sorted this problem out, it was a symptom of the sticky turbo vanes
    TwedA4 likes this.
    Nov 2013
    101
    nice one! i may have to do this too... i've noticed mine is a bit sluggish even when warm, other times it's off like a rocket!
  1. A4 TDI no power when cold and slight coolant loss
    By lukefaichney in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2012, 11:45
  2. B6 TDI 130 lumpy idle when warm problem
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2011, 23:45
  3. Power loss under load (TDi 130)
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2008, 14:03
  4. 1.9 TDI 130 PD power loss
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2008, 00:36
  5. HELP ! A6 TDI 130bhp keeps losing power when accelerating
    By tfox in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th November 2005, 09:48
