Chris NottSky Insurance
Results 1 to 23 of 23
Like Tree5Likes
  • 2 Post By crazyjay91
  • 1 Post By bez101
  • 1 Post By crazyjay91
Thread: Headlight switchback LEDs indicator/drl
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Follow crazyjay91 On Twitter
    Hi all,
    Just wired up some switchback bulbs in my headlights. Sat and done some working out with wires and using 3 relays and switchback bulbs got it all working for just over £15 if anyone is interested I can compose a diy for it.. Video can be seen here: https://www.youtube.com/watch?v=jwz9...e_gdata_player
    S4_dan and SmoothAssault like this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    you must have super sticky tyres on the car .
    S4_dan likes this.
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Sorry? Haha
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    These look good..
    What brand? From where?
    Any resistors required so you don't trip the bulb monitoring?
    Cheers..
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Quote Originally Posted by JasonS View Post
    These look good..
    Cheers..
    Thanks mate. The bulbs are off eBay £8.50. And spent £6.50 on relays.
    I already had the resistors but wired them in too so doesnt trip the bulb monitoring.
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    790
    So are those an extra set of bulbs in there? Isn't it an MOT fail if your side lights turn off when you indicate?
    I imagine you could get away with it if they were DRLs, but even DRLs only tend to dim when indicating. Not critisising what you've done, just concerned you may find your local MOT tester doesn't appreciate your hard work as much as we might.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Quote Originally Posted by SmoothAssault View Post
    So are those an extra set on bulbs in there? Isn't it an MOT fail if your side lights turn off when you indicate?
    Nope, completely separate to my sidelights buddy. The switchback bulbs house both LEDs for the white DRLs, and the amber indicators.. Not entirely sure about MOT wise but its just a case of disconnecting two plugs from the relays just in case they do dislike them haha the bulbs I used are these and I just did some minor alterations with them - http://pages.ebay.com/link/?nav=item...d=231069527849
    Dec 2007
    Cambridgeshire
    790
    ( I know those aren't actually your side lights as the location is wrong, but they wired up as side lights? )
    Dec 2007
    Cambridgeshire
    790
    Ahhh, I see!! That's quite clever!
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Thanks! They're wired up so they come on when I turn the engine on but go out when the indicator becomes active. I'll put some further info on here tomorrow
    SmoothAssault likes this.
    Dec 2007
    Cambridgeshire
    790
    Yes, please do. Very interested to see what everything's hooked up to and how you've avoided bulb warnings.
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Bulbs (x2) - £8.47 - 2X 3157 Dual Color Switchback Amber SMD LED Turn Signal Corner Light Bulbs | eBay
    Resistors (x2) - £7.79 - 2X 50W LOAD RESISTOR 4 SIGNAL INDICATOR STOP LED BULB | eBay
    5 pin relay (x2) - £4.34 - Automotive 12v 30A 40A 5 Pin Relay Amp | eBay
    4 pin relay (x1) - £2.35 - 4 Pin 12v 30A AUTOMOTIVE RELAY For Aux Lights Horns etc Car Boat Van Motorbike | eBay
    Total cost = £22.95
    Wire and female spade connectors also required!
    1. I started out by testing the bulbs - they have 4 metal poles coming from the base of the bulb (2 per side). Running 12v across them on one side lights up the white leds, and the other side lights up the amber. I bent the negative pole over to meet the other negative pole and soldiered a single black wire to this (so single wire feeds a negative to both sets of leds). I then soldiered a wire to the positive pole for the amber and labelled this, and the same for the white and labelled this one. You should now a bulb with 3 wires coming from it. Run 12v through the wires to ensure the bulb still lights up then wrap some electrical tape around the base of the bulb tightly to cover all of this over. Do the same for the other bulb.
    2. Get the headlights out. Take the original indicator bulb out - a small gap should be on the inside past one of the electrical connectors. Thread your 3 wires through this gap and pull out so the wires are near the back of the headlight bulb. now you should be able to put the original bulb holder back on to stop the new led bulb falling out (obviously take the normal bulb out of the holder first lol).
    3. Now for some wiring - please see below which wires go to which terminals.
    4 pin relay -
    85 - Goes to ground
    87 - 2 wires going to other two relays
    86 - Signal from engine on (found in a connector in engine bay a few inches from the back of the passenger side headlamp in a special holder. Pin 12, it's only small wire but this give a live when engine is running - tap into this wire)
    30 - Live from battery
    5 pin relay - one for left hand side indicator, one for right hand side indicator both wired in the same manor.
    85 - Ground (from the headlight*) and resistor wire 1**
    87a - To white positive on bulb
    87 - To amber positive on bulb
    86 - From Indicator positive wire (from the headlight*) and resistor wire 2**
    30 - From 87 on the 4pin relay
    * Two black wires inside the headlight the go to the indicator bulb holder. Cut these and check which one is positive and negative.
    ** The resistor wires go between the positive and negative wires that originally fed the indicator bulb in the headlight.
    At the moment the engine has to be on for the front indicators/hazards to flash but i'm going to wire a diode in between pins 86 and 87.
    Hopefully this all makes sense!!
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,614
    Very interested in this....if....you can keep the sidelights on and have hazards working without the engine running.
    Also, have you tried activating your alarm to see if the flashers still work as no engine running then?
    Dan
    2002 2.5 V6 Quattro
    Nov 2013
    101
    MOT wise... the new scania's have these, so i'd imagine it's ok!
    they have bright DRL's on the outside edges of the headlight and i though you wouldn't be able to see the indicators but they dim/go off when indicating.
    B6 A4 Avant 1.9TDI Sport 130
    Nov 2013
    101
    may i add, well done mate, i like it!
    might be an idea to add a wee fuse between the battery and your first relay. just in case
    Dec 2007
    Cambridgeshire
    790
    Great info! Thanks a lot!
    Like Dan, I'm interested to see how you get it working with the engine off, particularly for the lock/unlock indicator flash and hazard lights.
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    Quote Originally Posted by TwedA4 View Post
    Thanks buddy! That's a good shout to be fair haha! in line fuse holder has been ordered!
    Done! The diodes turned up and I put one across number 86 and 87 of the pins on both 5 pin relays. My front indicators now work again with the engine off for the hazards and lock/unlock flash and doesn't kick back with any errors when engine is running.
    Dec 2007
    Cambridgeshire
    790
    Haha, Nice work mate!! Get some photos uploaded when you can, would really like to see how it's all set up.
    Nov 2013
    101
    Quote Originally Posted by crazyjay91 View Post
    Is that from 86 to 87 or the other way around?lol
    S4_dan's Avatar
    Jan 2006
    1,614
    Great stuff. Can you add the links above for the diodes and fuse holders then please?
    Very interested in doing this mod.
    Maybe a mod could make this a sticky? Not necessarily in the B6 forum per se, but......
    Dan
    2002 2.5 V6 Quattro
    Dirty Diesel ♥
    Jul 2013
    Leicester
    126
    86 going to 87 - so the current flows out of 86 and into 87
    Quote Originally Posted by S4_dan View Post
    Dan
    No problem, I'll put this info on and get a couple pics at the weekend buddy!
    Nov 2007
    Very clever. Well done.
    S4_dan's Avatar
    Jan 2006
    1,614
    Any updates please Crazyjay91?!
    cheers.
    2002 2.5 V6 Quattro
  1. Headlights with LED DRLs
    By Billyboy200uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2011, 22:45
  2. Replace headlights with LED DRL units
    By bezza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2010, 15:21
  3. 09 headlights with led
    By gingers3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2010, 21:07
  4. Rear LED indicators--dont do it!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2010, 18:17
  5. AUDI A3 96-00 LED BLACK DRL R8 DEVIL EYE
    By guobin in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2009, 01:29
Tags for this Thread
