EM TuningChris Nott
    Nov 2013
    Help! Cant open the bonnet
    hello everybody!
    iam new to this forum, and iam not from USA so sorry for my english.
    i have an issue with opening my bonnet, its not opening.. the cable must fallen off from its shasies inside the engine bay.
    what is the way to open the bonnet when the intire cable mechanisem fail to work?
    i will be very thenkfull to any guidness or help..
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    Have you tried opening it whilst someone else is pulling the handle inside the car
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,685
    You can either break the grille, or pop the undertray off and use a long extension to get to the bolts from underneath.
    Nov 2013
    the handle is not responding at all, even when i pull it and someone push the bonnet down.
    about the grill, i managed to take it off withput breaking it, but there is one bolt under the bonnet that is quite far and not easy to open. if i open it, i will be able to open the bonnet??
    boost-addict's Avatar
    Aug 2011
    977
    as you have the grill off, use a small 10mm open end wrench to remove the 3 acorn nuts holding the hood to the latch,
    or
    push this latch to the right hand side of the car. (so drivers side if right hand drive, or passenger side if left hand drive)
    looking from
    underneath up.
  1. HELP WITH OPENING THE REMOTE KEY FOB TO REPLACE KEY PAD
    By shady-ninja in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2013, 08:40
  2. opening the bonnet
    By camerontarver in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2012, 20:05
  3. Help..Cant get the Audi A4 jack back into its storage container in the boot?
    By larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2011, 16:09
  4. Help can't open the hood on 2005 a3 2.0 tdi bkd
    By Tuteh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2010, 21:51
  5. cant open my bonnet
    By slight_problem in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2007, 16:22
