Sky InsuranceChris Nott
Results 1 to 12 of 12
    Oct 2013
    East Sussex
    208
    Heater blowing half and half!
    Hello all, using the blowers this morning and set the temperature which was lovely and toastie my side but the vents on passenger side were blowing cold air. I don't have access to VCDS only a fault code reader of eBay.
    It's literally split down the middle of the centre vent and the one on each side. If I close the vents on passenger side it directs the cold air through the vents my side. I thought I was going mad and had the passenger temp set to low but they were both on the same settings so I'm lost.
    Anyone got any pointers, much appreciated
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    one of the flaps with be stuck or need a new motor
    bez101's Avatar
    Jul 2008
    7,926
    or you have the pass side set lower than the drive side
    Oct 2013
    East Sussex
    208
    Ok cheers, I'll have a look at weekend
    bez101's Avatar
    Jul 2008
    7,926
    remove glove box
    and you can check the motors in turn and watch for them moveing
    Oct 2013
    East Sussex
    208
    That's great, hopefully it is just the flaps and not the motor
    Oct 2013
    East Sussex
    208
    Ok couldn't get round to it last weekend and it was still blowing the same up until tonight where everything was working as it should. Any ideas?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    Quote Originally Posted by A4sportMrT View Post
    Dirty connections to the flap motor(s)? - I found this was the problem when the passenger side was only blowing cold a few months ago. Cleaned the contacts and it's been fine since.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2013
    East Sussex
    208
    I'm still gonna have a look but I'm at brands hatch this weekend, I'm hoping to be able to squeeze an hour or so to get the glovebox out and look. But thing that is puzzling me, is that I've done nothing or altered any settings. Maybe magic
    Jul 2007
    765
    Same with mine on the screen vent.Nothing then after trying the switch a few times it came back and has been Ok since.I guess the cogs sometimes don't mesh right but I wont touch it unless it comes back
    Oct 2013
    East Sussex
    208
    That make sense and sounds possible, I had the blower on full on screen only tonight when I finished work and closed the 4 forward facing flaps. And once the screen was clear I just shut it off and heard it all shut down so perhaps it's sorted it self.
    This was before I realised that everything is now working tickety boo
    Jul 2007
    765
    I don't tend to change settings a lot but now I fiddle more cos I think things like to be used and fail more when neglected
  1. Heaters blowing some cold air?
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2012, 08:30
  2. Air con blowing hot and cold ????
    By Rabbid in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2011, 08:28
  3. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  4. S3 half leather/ half Swede seats
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2009, 15:44
  5. heater blowing cold air please help!
    By dannyoct16 in forum General Technical / How To
    Last Post: 1st January 2005, 22:19
