Volks AutosAH Fabrications
    Oct 2013
    Doncaster
    7
    Brake pedal switch?
    Hi folks,
    On the way home visiting friends tonight, I had a guy behind me flashing his lights. After 5 mins or so I pulled over to see what the guy was flashing for. He said my central brake light was constantly on. 2 mins after, the glow plug warning light comes on. I pulled over, turned off the engine for a think! Started the engine with no loss of power, no rough running so I drove back home for an investigation. Had a quick look at the fuses, fine, then mucking about with the lights before I looked on here. I've seen people have had this fault before with the brake lights coming up and ecu warning flashing. Could it be the same problem, ie the brake pedal switch? Anything else?
    pauldazzle's Avatar
    Cardiff
    553
    Sounds like your brake pedal light switch is failing (common problem).
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    quick easy fix
    new switch
    pauldazzle's Avatar
    Cardiff
    553
    When you fit the new switch contrary to several sources on the net do not depress the pedal, but make sure the switch clicks when you twist it into position, if it doesn't click it wont work. The switch is supplied in the locked position & the click is the lock disengaging.
    I had to replace both the brake & clutch switches on my A4 within a month or so of each other last Spring, easy job.
    Oct 2013
    Doncaster
    7
    Smashing that, thanks very much for your help!
  1. Brake pedal switch - fitting instructions ??
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2010, 22:25
  2. Replies: 5
    Last Post: 20th May 2009, 14:23
  3. brake pedal switch
    By soulman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2007, 12:24
  4. A3 brake pedal strange feeling
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2004, 19:01
  5. unusual brake pedal kickback
    By imported_bayliss in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 17:56
