Badger5Volks Autos
Page 1 of 3 123 LastLast
Results 1 to 40 of 86
Like Tree16Likes
Thread: How to get rid of ABS dash lights after fitting HIDS.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Fitted my hids the other night then straight away ABS etc warning lights come on.
    What I've learnt, expensive hids, cheap hids it's pot luck whether they'll throw the abs lights up.
    Moving the ballasts works for some people for me it didn't.
    The ground to the near side headlight shares the same ground as the abs sensor along with other grounds.
    So to remove the headlight ground to another place made sense not to interfere with the other grounds.
    Here's some pics and a rough guide what to do.
    Only do this if your confident in not messing it up and can put back to original setup if things go wrong.
    In other words 'Don't blame me if you balls it up'. Lol
    So I removed near side headlight, turned hids on and what do you know, no dash lights! That's a start, so it's defo this side that's causing the dash lights.
    Unplug the headlight plug and the wire you need to cut is wire 10.
    Cut the wire about 3 inch from plug.
    The wire coming from the car, cover up and forget about it.
    Find a wire roughly the same thickness (14 gauge) and solder/clip onto ground coming from the plug.
    Ground the other end of wire to the windscreen washer bolt. I added another washer onto the bolt to sandwich the wire in.
    Tighten.
    Fit headlight back in, making sure to cover any exposed wire.
    Get in car, turn hids on. Hey presto no dash lights.
    Works for me and other people I know but I can only hope it works for you.
    My ballasts are under my headlights for any one wanting to know.
    Like I said, just a rough guide, but you get the idea.
    Kris
    Sep 2013
    Portsmouth
    245
    Will be doing this when I fit mine.
    Thanks for the pointers in the right direction.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    Mine used to do this,so just turned ignition on and off. Worked for me.
    But has stopped doing it now?
    Cant complain.
    Good thread for some :-)
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Nice write up, I'll add it to the DIY stickies.
    vr6gordy and krisavant like this.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Mine are located in the same place as yours... sometimes I get the warning, other times I don't. It's about a 20/80 split (don't/do). I'm going to do this as it seems to fit with my intermittent warning lights. Thanks a lot!
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Jul 2012
    432
    Unplug or take out near side headlight first, then turn lights on.
    If abs lights don't come up then you know its more than likely the earth that needs relocating.
    benjie's Avatar
    Oct 2009
    645
    Only thing is that they don't always cause the warning then I turn them on, so there's no way to be sure. I'll just do it anyway, it's only a 10min job.
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    Done this earth mod yesterday and all seems fine now. Ten minutes work if that. Good solution to a nippy problem. Cheers kris.
    krisavant likes this.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    Guys have you all been doing the nearside headlight (passengerside)
    Jul 2012
    432
    Yes.
    Jun 2013
    54
    Has anyone had problems with high beam staying on after fitting hid lights? I've fitted two kits both main and high beam. But not moved the earths yet.
    BRILLO's Avatar
    Sep 2011
    137
    Quote Originally Posted by krisavant View Post
    Yes.
    . Also yes.
    Jul 2012
    432
    Quote Originally Posted by Deeming77 View Post
    Haven't fitted high beam myself.
    Is the main beam turning itself off or staying on after you've switched them off?
    Jun 2013
    54
    They are switching off when switched off. Its just the high beam won't stay on when push the stalk forward but flashes when stalk pulled back. And soon as the head lights turn on all fog lights go off. Even though they work with the side lights.
    Jul 2012
    432
    Jul 2010
    217
    I fitted HID's yesterday.
    Fitted everything inside the headlights like the DIY guide.
    And as expected the ABS light flashed up. So did the earth relocation and when started last night it sorted it fine.
    Started up this morning and it didn't do ABS, but then next time I turned it on it did ABS. Not sure if it was because I turned car on then flicked lights on quickly as restarted at the lights and it went.
    So even with the earth relocated maybe need to let the car settle for at least a few seconds before switching on?
    Jul 2012
    432
    Couple of checks..
    Disconnect passenger headlight then turn ignition on. Do abs lights come on?
    Jul 2010
    217
    Yer before I had done the earth mod the ABS light came on when Passenger light in and then ABS went once headlight out.
    Jul 2012
    432
    Was no. 10 on the plug deffo your earth & the raw end of wire coming from car taped up?
    Jul 2010
    217
    Yep all done as guide.
    Jul 2012
    432
    Can't understand how the hids is inter fearing with the abs earth?? I can only suggest moving the earth well away from the wing and wrap hid wires in an inner tube or something similar to stop interference.
    Jul 2010
    217
    I'll double check everything and run for a few days and see what happens.
    maybe see if theres a bolt on the chassis legs i can piggy back the earth onto?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    This started happening on my 1st pair of hids,what i kep doing was turn ignition on (1st turn) then if lights errors flashed,turned off,then turned on again,full ignition on. No probs.
    Thing is its as if its learnt about the problem because it doesn't do it anymore??
    To prove it again,got my 2nd pair of hids,repeated above...now at point it doesn't do it. Again!
    Strange, but happy.
    BRILLO's Avatar
    Sep 2011
    137
    I've had no problems at all since doing Kris's mod. I think every a4 has a different temperament to hids. Lol. Mine as well as Kris's were 100% error free. Not so it would seem. Lol.
    Jul 2010
    217
    Well had some time to work things out and although not fixed I've learnt how to avoid the warning.
    If I turn the switch to dipped beam before I start the car. When I start the engine the HID's come on no issues.
    If I start the car and turn on HID's within say 10 seconds I get the warning.
    If I turn the HID's on after 50 off metres..... no warning.
    Bizarre I know but thats what seems to work.
    I don't know if it has anything to do with me screwing up the mod to begin with. I originally soldered the relocation wire to the earth going into the car loom. Was a frantic 20 mins swapping HID bulbs about thinking I had blown one, until the penny dropped. I left the car loom wire with 2cm stripped with solder on it but wrapped in gaffa tape. Maybe if I trim it back it could help?
    Jul 2012
    432
    The car loom you wanted to avoid because that's where the abs earth is grouped with.
    You need to insulate the exposed wire with electrical insulation tape.
    Where have you earthed the wire coming from headlight plug?
  28. #27
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    Getting this into my posts for when I do my hids in the new year.
    Made on the red side of Manchester
  29. #28
    Greeny233's Avatar
    Mar 2011
    Llangollen
    688
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    I just moved the ballasts as far away from the ABS unit as possible, worked a treat not had a problem in over 12 months.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  30. #29
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
  31. #30
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
    Do you have to do this in both sides or only the driver side?
  32. #31
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Only the passenger side unless your car is a left hand drive? The ABS unit shares the same earth wire as the passenger headlight.
    2002 2.5 V6 Quattro
  33. #32
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
    Quote Originally Posted by S4_dan View Post
    Thank you, and yes my car is a left hand drive.the earth wire has to be exactly the sme thickness (14 gage) or it could be a little more thicker?
  34. #33
    Mar 2011
    141
    Quote Originally Posted by Greeny233 View Post
    Yes, that's the solution.
    High voltage cables & ballast as far away as possible.
    I was able to avoid this issue just by moving the ballast & cables. Also by shielding the high voltages cables with aluminum foil.
    If the earth wire was the problem, moving the ballast or using aluminum would do nothing.
  35. #34
    S4_dan's Avatar
    Jan 2006
    1,600
    You can use thicker wire if you wish or the same. Just don't too go much thinner.
    2002 2.5 V6 Quattro
  36. #35
    benjie's Avatar
    Oct 2009
    645
    I did this a month ago and no warning lights, so guess it's all sorted. Thanks!
    krisavant and nefA4 like this.
  37. #36
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
    Sorry, whats a car loom?
  38. #37
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
    Quote Originally Posted by nefA4 View Post
    And i screw the earth wire exactly in the same place where u show on the mod, and i did the sandwich just like u show i think thats the wiper washer screw.
  39. #38
    Jul 2012
    432
    I was referring to the wiring coming from the car at the time of conversation.
  40. #39
    Jul 2012
    432
    Are you asking for advice?
    Or you saying this is what you have done?
  41. #40
    nefA4's Avatar
    Dec 2013
    miami fl,usa
    64
    Yes im asking for advise, if posible
  1. Check Engine Light after fitting 3" DP and 200 cel cat
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2012, 12:09
  2. Replies: 2
    Last Post: 31st May 2012, 13:35
  3. Coding change after fitting HID's?
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2010, 18:26
  4. ABS Dash Light
    By steviet in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2010, 20:43
  5. Can't get rid of ABS/brake pad warning light...
    By theboxtv in forum A8/S8 forum
    Last Post: 8th November 2009, 20:04
