EM TuningJMB Retrofits
    Exhausted
    Oct 2008
    Clitheroe Lancashire
    Xmas has come early on my dashboard
    Hi Guys, I may be repeating and old question already covered but cant find a thread.
    After fitting my new headlight kit from the group buy from Trupps I have promlems with dash lights i.e. Brake Warning,ESP,Handbrake all lighting up !!! when the lights are put on before the engine all is OK !!!!
    One last quicky, were will can I find the sensor/temp that controls the gauge in the car dash disply ???
    V6 30ltr sport avant july 2002.
    Thanks in advance of any help.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    first off i would contact trupps as he sold you the lights
    i think the CTS is at the rear of the engine.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Warning lights are common when fitting HID's, the easiest way to resolve is to relocate the ballasts as near to the bulkheads as possible.
    I'm sure there's a guide for swapping the Coolant Temp sensor (G62) on the 3.0 on Google somewhere?
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,802
    As James said, move the ballasts as far back as possible. I had errors when I first fitted kine (not ones from trupps) but I moved them back. Drivers side is up near air con pipes, passenger side is near abs module (think that's what it is) and I haven't had a problem on 18 months now.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    You only have to play about with the near side ballast as that's where the abs/speed sensor are.
    The near side headlight shares the same ground as these.
    Either move ballast away from these or re wire the headlight earth somewhere else for a permanent solution.
  1. CHRISTMAS HAS COME EARLY : )
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2011, 19:17
  2. Christmas has come early for my S3
    By will_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2007, 12:01
  3. Airbag light has come on - help?
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2005, 07:44
  4. It has come to my attention
    By BerkshireFlipper in forum General Chat
    Last Post: 29th September 2004, 15:17
  5. Finally my time has come
    By imported_mustwin1 in forum The Welcome Section
    Last Post: 9th July 2004, 16:40
