Monster MotorsportChris Nott
Results 1 to 8 of 8
    Oct 2013
    6
    Poor starting tdi 130
    Hi all,
    I've got a 2002 tdi 130 (103000miles), normally it's a really good starter - as soon as the key is turned. However over the past month it's taking longer to start from warm, sometimes it's takes 3 or 4 seconds with it occasionally taking a few go's of turning the key. It's regularly serviced and had just had new filters , and the only fault code that is coming up is for an engine mount sensor. Other suggestions by friends are injectors and pump clearances. I'm going to fill up at a different forecourt and add injector cleaner to see if that makes any difference.
    I have done a search but it hasn't brought up anything with the same symptoms. Any advice would be appreciated.
    Thanks in advance
    Leigh
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,416
    Car battery with the weather getting colder and also possibly dead glowplugs. I had three of mine die and the battery was also weak and had similar symptoms last autumn.
    All replaced and started strong and quickly
    Mike
    pauldazzle's Avatar
    Cardiff
    558
    A minimum of 250rpm is needed to start a PD engine, so its worth jump starting off another battery, & if it starts normally then your battery is getting tired.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Oct 2013
    6
    Thanks for the ideas, will try jump starting it next time (had a new bosh battery about 2years ago as well) if that fails will check the glow plugs.
    Oct 2009
    Hull
    1,433
    flick your headlights on before starting and see if that changes anything
    the switch develops a fault in the off position and causes the same problems
    Oct 2013
    6
    Thanks for the suggestion, I tried the lights and it turned out to be the cause so I'll get a replacement light switch. Glad it's nothing more expensive/ time consuming. Cheers.
    Oct 2009
    Hull
    1,433
    lol wait till you see the price of a genuine switch!!
    have look on here for the ebay ones they are only about £20
    Oct 2013
    6
    Just an update, fitted a replacement headlight switch in early December, and everything has been perfect since, so thanks for the replies
  1. Poor MPG Audi a4 1.9 TDI 130 BHP Sports 2004 / thermostat??!
    By Sam84 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th December 2013, 07:37
  2. starting?TDI 130. MPG? CAN YOU HELP?
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2012, 19:56
  3. cold start issue tdi 130
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 16:16
  4. 1.9 tdi 130 starting issue
    By tnsl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2010, 19:05
  5. VW Passat TDI 130- poor urban MPG?
    By chrisb1969 in forum Diesel forum
    Last Post: 9th December 2008, 11:13
