EM TuningSky Insurance
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    Belt tensioning damper - 059109479B
    Just checked my timing belt kit and noticed that there is no belt tensioning damper included! When I spoke to the guy at Audi he said 'EVERYTHING' was included in what they call a 'REPAIR KIT'.
    Is it imperative that this part is changed?
    Car is booked in for 08:30hrs tomorrow. No chance in picking one up today. Or at least not a genuine one.
    Are aftermarket ones ok to use? The rest of the kit is Genuine Audi parts.
    Dan
    2002 2.5 V6 Quattro
    glenandem's Avatar
    Sep 2012
    manchester
    446
    its more than advisable pal,what happens if you replace the belt then the bearings in the pulley or tensioner go!
    also not essential but while its being done i always throw a waterpump on for the sake of a few quid more as that could start leaking or bearings go again!
    if you cant afford audi just go for something like a gates, most manufacturers use them anyway!
    glenandem's Avatar
    Sep 2012
    manchester
    446
    just reread your post and noticed you said no tensioner, thought you meant the little roller puller that comes with most kits too!, in that case i think its definately advisable to replace the tensioner at the very least!
    out of interest what did you actually get in this repair kit,was it just a belt?
    might be best taking it back and go soemwhere like gsf or euro carparts and get a full kit that usually includes the belt tensioner and the little roller pulley!
    S4_dan's Avatar
    Jan 2006
    1,503
    I have 3 new pulleys in the kit. 2 x roller and 1 x tensioner. 2 x belts and a cover and a bolt. And a new water pump. I'm referring to the 'grenade' style hydraulic tensioner. The one with a safety pin when it's brand new.
    Like this:
    Dan
    2002 2.5 V6 Quattro
    glenandem's Avatar
    Sep 2012
    manchester
    446
    sorry im getting confused,you said you didnt have a tesnioner in kit in first post then youve just said you have one now?
    if you dont have that then ideally you need it as ive replaced belts on peugeots with same style tensioner and weve always replaced them for good measure!
    S4_dan's Avatar
    Jan 2006
    1,503
    Quote Originally Posted by glenandem View Post
    No, my first post said 'no belt tensioning damper', not tensioner per se lol.
    It is confusing.
    I'll have to try and source one then but with car in the garage tomorrow morning, I may have to let them try and get hold of one. If not, I remember changing this on my 2.8 V6 Audi, iirc, it is fairly accessible and could be done at the weekend after the belt and pump change?
    2002 2.5 V6 Quattro
  1. TIMING BELT TENSIONER DAMPER (06B 109 477)
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2011, 11:55
  2. what Timing Belt,tensioner,water pump..
    By griffin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 22:23
  3. Cam Belt/Tensioner Change
    By imported_shipp in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd January 2005, 00:55
  4. 1.8T Cam-belt tensioner differences?
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2004, 22:50
  5. Cam Belt Tensioner - Known Issue??
    By Anito in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th March 2004, 07:55
