Volks AutosEM Tuning
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Did my drain grommets today
    Also while faffing about with the EGR, I decided to remove the battery and check the drain grommets had been removed especially after it was in QRSport just before I bought it for water ingress. To my surprise, the bungs were still in situ.
    13mm ratchet spanner fits perfectly to remove these nuts quickly
    Bung removed under battery tray
    I couldn't fully remove this bung as there is a pipe running through it? Anyway, I manage to slide it up the pipe and wedge it place so it's no longer blocking the hole. You can just make it out in the pic.
    Although there was no water present when I removed the battery and the bungs were fairly clear & clear, probably been cleaned out by QRS recently.
    Along with the ECU box trapped wire I sorted couple of weeks ago, hopefully that will spell the end of any water ingress!
    Dan
    2002 2.5 V6 Quattro
    glenandem's Avatar
    Sep 2012
    manchester
    528
    How hard I'd it to get battery out pal, I got a battery to fit when I can be bothered and just wondered as there's an Allen bolt isn't there down the back?
    Jul 2010
    217
    Whoops, think I removed the wrong one then.
    I couldn't be bothered to remove the battery so pushed out that big oval one. Was the only one I could see as it was getting dark, had the desired effect.
    S4_dan's Avatar
    Jan 2006
    1,600
    Quote Originally Posted by glenandem View Post
    It was a bit tricky but I used a 6mm allen key on a socket with an extension bar, 3/8ths. Hardest part was getting the bolt started when refitting it. Ended up using a long thin flat head screwdriver (big enough to fit in allen bolt and turn it) to get the bolt started. When I tried with the socket allen key it was wrong angle. I also had to unclip the ECU wire out of the way for access too.
    Quote Originally Posted by Paul_TDi View Post
    I noticed the large oval bung too but then spotted the rubber drain grommet under the plate. Not sure where that big oval hole leads to......
    Dan
    2002 2.5 V6 Quattro
  1. Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2012, 21:04
  2. Did The N249 Bypass Today....
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2011, 17:55
  3. Did show n shine with the Audi today....Pics
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2008, 16:12
  4. A4 Cab ordered today - did I get any of my options wrong?!!
    By timjhoward in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th August 2007, 21:52
  5. Did some simple mods today - not just on the S3!
    By dog fart in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2007, 20:26
