Sky InsuranceVolks Autos
Results 1 to 12 of 12
Thread: Airbag light on
    Oct 2009
    Kent
    314
    Airbag light on
    Hi guys, can anyone help, my car a4 avant 2.0l fsi has failed the mot on the airbag light and it's saying that it's the drivers side, side airbag sensor can anyone tell me how easy-hard it is to do or is it a garage job.
    many thanks Jay
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,433
    whats the fault code ?
    it can be a very easy job or a new bag
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    221
    I had a problem with my passenger side one,
    disconnect the battery, leave 1/2 hour then unplug the connectors under the seat, give the pins and connectors a clean, squirt with WD40 and connect back up.
    you will need to get the light reset though through vag com
    Ross, MK5 Golf - R19 DUB, Audi A6 C6 - R19 RRW
    Oct 2009
    Kent
    314
    Thank you for your replies, the garage I take it too is a friends and he only has a snap on tool but it's saying its a fault with the offside airbag and when it was at audi last year they said it was that 1 too and would cost £300 plus vat to fix. Is it an easy fix myself as in do the plastic panels just pull off as cannot see any fixings.
    Cheers Jay
    bez101's Avatar
    Jul 2008
    8,433
    remove airbag plug for that seat
    clean and refit
    then have the code cleared
    if that dont work it could be the wireing under the seat this needs the plug cutting off and rewireing
    then the fault cleared
    if that doesnt work then its new bag time
    Oct 2012
    426
    There is fix for the wiring loom under the seat that comes out of the carpet, basically the existing loom is too short, get it reset with vcds and see if it comes back
    Oct 2012
    426
    If you fancy a trip to east sussex i will do it for you
    Oct 2009
    Kent
    314
    Quote Originally Posted by Ian2012 View Post
    I'm interested do you want to private message me with a price or on here.
    Cheers Jay
    Oct 2009
    Kent
    314
    But is this for the seat airbag and not the pillar bag.
    Cheers Jay
    Dec 2006
    barnsley
    1,013
    is it the front side airbag or the rear side airbag
    might be an idea to have a look on the vcds map on here and ask a member if he could possibly scan the car for you to get the exact fault code
    sometimes they will clear easilly , you may have to clean the connector and plug with electrical contact cleaner
    after this replace the plug and connector is this doesnt work
    its either a new airbag or replace the airbag with a suitable sized resistor to simulate the airbag still being in circuit
    this will enable the rest of the airbags to fire in case of an accident but obviously not the faulty one
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by jolly14 View Post
    Sensor or airbag? The description you've been given is vague - you need to know exactly what the fault is being caused by. Get someone with VCDS to scan your car and note EXACTLY what the code and description is.
    99 times out of 100 it's caused by a bad connection to the side airbag in the seat.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2009
    Kent
    314
    Thank you for your help, I'm sorry it's a bit vague but that's my friends equipment at his garage but I will be taking it to a garage that has the vcds tomorrow and then I'll post up the codes.
    cheers Jay
  1. A6 tdi airbag light on! looking at purchasing car?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2005, 21:57
  2. Passenger Airbag Light
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 14:29
  3. abs airbag light
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2004, 18:46
  4. Airbag Light
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 16:18
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
