JMB RetrofitsVolks Autos
Results 1 to 10 of 10
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Exclamation The dog has surpassed itself this time!!
    Coming back from the putting some fuel in this dog i've recently bought (2.5Q) and as I was coming down a 'steepish' hill at about 40mph there is a sharp right bend, road condition was wet but not raining or surface water, anyway, as I turned right quickly without braking the car juddered (no acceleration/brake applied) like i'd hit a huge puddle and I noticed that my TC light was flashing away then stopped. Also I heard/felt the ABS kicking in. It came from the front left wheel.
    So as I was driving along the straight stretch, no other traffic about, I started to throw the car to the right then left. Every time I threw it right, the TC light flashes and ABS kicks in on the front left wheel! Only does this when it's a fast/quick turn right on the steering wheel.
    Anybody else ever had their Audi brake for them when turning quickly? My concern now is what if it just jams the brake on on the front left when driving along?
    When I got home, I checked all brakes for heat and it was even, so it doesn't appear to be a sticky caliper causing lock up on wet roads....
    I'm amazed and shocked at the same time.
    Not done a VCDS yet. Will do that shortly.
    Dan
    2002 2.5 V6 Quattro
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Were you going quick enough to loose traction?
    If im going quick or out for abit of a hoon I usually turn off TC.
    It sounds like you may have an ABS issue though, possibly a dirty sensor / corroded ABS ring on that wheel.
    Sometimes mis-matched tyres can also cause this when "spirited" driving is taking place.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    mikeygulley's Avatar
    Aug 2013
    Paignton, Devon
    30
    Add mikeygulley on Facebook Add mikeygulley on Google+
    I had it happen once on very wet leaves going down a steep twisty hill (my favourite run in the pug!), I was pushing it! hahaha
    S4_dan's Avatar
    Jan 2006
    1,600
    No I wasn't really pushing it, I normally do as it is a good road and motorcyclists love it too. 40mph which is a bit quicker than someone would normally take the bend, but certainly not an excessive speed. Even on the straight I was only doing 40 again.
    It has four matching tyres and tread depths, Bridgestones I think they are. 6mm all round.
    I'll be changing the rear discs and pads soon so will check the front whilst I'm at it.
    Dan
    2002 2.5 V6 Quattro
    Jul 2010
    217
    I had this happen on my old A3 1.9Q, going round a feeble corner at normal speed and left wheel (turning right) started braking.
    I'm pretty sure it was my shot wishbone bushes causing this issue. I had the bushes changed a week later and solved the issue. Put it round same corner at increased speed and just stuck to the road.
    glenandem's Avatar
    Sep 2012
    manchester
    528
    i'd be checking your abs ring pal on the cv joint, if its gummed up with crap or corrosion then just try a wire brush on it and clean out the grooves,see if that helps!
    S4_dan's Avatar
    Jan 2006
    1,600
    Quote Originally Posted by Paul_TDi View Post
    Ok, Will get them checked. Car is in the garage on monday for timing belt job so will get them to check the bushings as it's due an MOT soon.
    Dan
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,600
    Quote Originally Posted by glenandem View Post
    Cheers for that, I will have a look when I do the rear brakes. Strange how it only did it in the wet and never has any other time when I've been doing some 'spirited' driving and with plenty of understeer!
    Dan
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,238
    You could hit a patch of greasy road and/or your tyres grip badly in the wet allowing the TC to kick in in these conditions... Most "budget" tyres have poor grip in the wet so even if they are matching and the car is a quattro it might be not gripping mechanically before the electronics take over. As above i would check the ABS sensor readings in VCDS but it will be a red herring as the ESP will sense that and the TC will be on the dash ! What it could be is crud/metal filings on the ABS sensor that could give a false reading so the ABS system thinks one wheel spins faster than the other, again monitoring the sensors will shed some light on the matter. Just remember that the ABS system will drop communications if speeds are above 20 Mph so it might be inconclusive but look for differences in the readings...
    FOR SALE:
    S4_dan's Avatar
    Jan 2006
    1,600
    Cheers Chris, tyres are Goodyear EfficientGrip all round. Will give the VCDS a go tomorrow after I've done the brakes. Hopefully nothing too serious!
    Thanks for your input, as ever, it's much appreciated.
    Dan
    2002 2.5 V6 Quattro
  1. Will the problems never end... well this time I have had enough!!!!
    By mumra in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2012, 22:36
  2. Another problem...This time the clutch
    By tonythetiger in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2011, 17:41
  3. More probs with the S3..suspension this time :(
    By themanthatcan in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2009, 11:47
  4. the ripsaw at alton towers has nothing on this...
    By audi80sport in forum You Tube Links
    Last Post: 12th October 2007, 16:46
  5. Strut Brace for the A3 - has anyone done this mod?
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 20:36
