Sky InsuranceChris Nott
Thread: lights problem
    Mar 2013
    Wallasey merseyside
    lights problem
    hi all, not sure if this is the right section, but had a prob with my rear lights and indicators and dash lights! they have stopped working. i had a leak throu ecu box thats sorted now with new seal etc. my cooling fan is also randomly kicking in i persume this cud be a fault with the relay 219? any help wud be great.
    thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    did you check the relays in the ecu box the water can will damage them
    also in the car under the ecu is a CEM runs the lights if water has got in there this can be your problem
    needs removeing (very easy) and opening up to check for water damage
    Mar 2013
    Wallasey merseyside
    some of the relays where wet, goin to replace 219 as this is the fan one, the other is a glow plug one not to sure on 395. whats the cem? sorry not to clued up on this part of cars lol
    bez101's Avatar
    Jul 2008
    8,491
    central electrics
    its under the dash kinda behind the headlight switch
    very comom for warter to get in there from ecu leak
    Mar 2013
    Wallasey merseyside
    Hi again I've sorted the fan now and also had to replace battery had the car running and heating goin to dry carpets out. Lights didnt work at first now they are but sometimes flicking on an off. Could this be just wiring drying out an they shud be ok or will I need to replace more stuff?
  1. Dash board light problems??
    By Vorshprungdork in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th November 2005, 19:12
  2. Wierd timed / auto lights problem
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2005, 19:47
  3. Mechanic gives up on Emissions Light problem...
    By vpg_ii in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th January 2005, 16:00
  4. Finally my ABS Light problem is sorted
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 20:40
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
