Sky InsuranceJMB Retrofits
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    01218 airbag fault fixed
    Had this fault for a while with the airbag on on dash. After reading several sites,i decided to diy.
    Very easy. Pump seat up,move forward.go undeneath and locate yellow plug.note the two different colour wires. Cut off plug. Reconnect wires.
    Airbag light off. Did have to clear it with my cheap code reader.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    My MOT test is due on Friday and my Airbag light decided to come on with the same code.
    I performed the same procedure in my Cabriolet for the passenger seat;
    Disconnected battery.
    Moved backrest as far forward as it goes.
    Removed bolts from rails
    Tilted seat back so I could get under.
    Located yellow plug and cut off
    Snipped the cloth tape so I could get enough slack to join the wires
    Stripped the wires back, slipped on heat shrink tubing, twisted and soldered, warmed tubing, wrapped in electrical tape and zip tied to plastic mount.
    I then re-attached the battery, cleared the code and it hasn't come back.
    Unfortunately when I reset the steering angle sensor, I tripped the ABS code 01486 - System Function Test activated.
    I drove down the road slowly and turned left, which seemed to satisfy the ABS module and the code cleared, so I was lucky..
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    Quote Originally Posted by deano1978 View Post
    yep very common
    iv posted the detailed diy a few times
    what wire did you use and did you solder ?
  1. Recurring airbag fault 01218
    By kip in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2012, 23:24
  2. Airbag fault getting annoying - '01218'
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2010, 12:09
  3. Airbag fault
    By Big Daz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2010, 01:20
  4. Airbag Fault Can you Help???
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2009, 21:50
  5. Seat Airbag Fault?
    By NineNails in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2009, 22:35
