Chris NottSky Insurance
Like Tree1Likes
  • 1 Post By Paul_TDi
Thread: those with the decat pipe and egr delete
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    534
    Because of my rear exhausts,egr delete,middle and rear back boxes gone and remap,im starting to get fed up of cleaning the rear of soot!
    So im thinking is the full decat pipe from the turbo going to improve things or make it worse? With the existing cat is it full of soot and every time i boot it,it just chucks it out.
    And any reviews of the full decat ?
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Sep 2013
    hi if you install a decat pipe gain a extra power and quick response time. but will be lauded and and possible flames will come of the exhaust and you will not pass the mot.
    i just done decat for myself and my brother and is better. but i will suggested to make a full stainless steal exhaust to improved your exhaust
    Sep 2013
    hi if you install a decat pipe gain a extra power and quick response time. but will be lauded and and possible flames will come of the exhaust and you will not pass the mot.i just done decat for myself and my brother and is better. but i will suggested to make a full stainless steal exhaust to improved your exhaust.
    also you can try fit only straight pipe, before you just to meke sure that will work because not on every diesel that will be better.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    534
    Flames from a diesel !?!
    Its already s.s exhaust.
    Diesels have no probs with decats at mot time
    Jul 2010
    204
    I had a full miltek decat non res on my mk4 golf with a PD130, mapped, EGR delete, custom SMIC and the sound was beautiful and I had no smoke or soot issues, I had opted for the discrete tail pipes so can't comment on soot on body work.
    actual lol at a flaming diesel.
    BRILLO likes this.
  1. One for those with the 300mm rear brake set up...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2012, 11:20
  2. If you use AMI then watch out with the new iPhone and iPod Touch
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2012, 15:42
  3. Out with the Old (new) and In With the new 2012
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2012, 08:18
  4. A couple more pics with the new wheels and eibachs on.
    By Gates in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2012, 06:44
  5. ABS fix, for those with the dreaded light on
    By JLA in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2008, 18:21
