AH FabricationsChris Nott
    Oct 2013
    Doncaster
    7
    Knocking on the front end.
    Hi peeps,
    New member so go steady on me lol! Got an a4 quattro sport tdi, and there appears to be a knocking noise coming from the front end somewhere. I originally thought it could be the drop links that were shot but after changing them, it still hasn't solved it. It's not either of the cv's as it's fine when the wheels are turning left to right. I can't work out wether it's from the left or right either. Any common faults with this happening? I'm now guessing it's either the top mounts, arb bushes, or the upper arms. All this easy enough to change for a DIY mechanic with no access to a press?
    Thanks for your time, any help is appreciated as it's winding me up!
    Oct 2012
    434
    Could be upper or lower arms
    Dec 2006
    barnsley
    1,020
    upper arms have a tendency to go and they are notoriously difficult to get off
    as the pinch bolt on the front suspension is usually seized
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
  1. my car is knocking on the front end for some reason
    By jamesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2013, 00:12
  2. Is the front end the same on a B7 cab and saloon?
    By dhillon884 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2010, 18:17
  3. Tarted up the front end
    By norm29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2009, 13:36
  4. Knocking from the front during gentle braking ???
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 22:29
  5. Knocking on the front suspension !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2007, 10:26
