Sky InsuranceJMB Retrofits
    Jan 2013
    11
    Power Steering A4 !.9TDi HELP
    Just been out in car and battery light came on,stayed on and trying to turn the car was like trying to turn the Titanic.Is this most likely to be the power steering pump or could this be something else.If so what kind of price will pump be.
    Still a beginner at all this car maintenance stuff so be kind.
    Oct 2009
    Hull
    1,440
    auxiliary belt has come off or snapped by the sounds of it
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    Yeah as Stu says... belt has either come off or more likely snapped.... the same belt drives your alternater and power steering pump.... the battery light is a sign that the alternator isn't turning due to the lack of belt
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Jan 2013
    11
    If this is the case and it is a belt then am I right in saying this should be quite a cheap and easy fix.Like I say,sorry for the lack of knowledge but we all got to start somewhere eh
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You'll just need to know why the belt has broken etc, maybe it was just worn out, but maybe one of the pulleys has wear and has thrown it off or something.
  1. power steering fluid DUMP!! HELP!
    By the joe s4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2011, 15:10
  2. power steering pump problem (help)
    By Shawny-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2011, 20:55
  3. Checking Power Steering Fluid level!! Help needed asap!
    By scott_johnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2010, 08:24
  4. power steering fluid check help
    By m.dub in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2010, 17:58
  5. Power steering problem-please help !!
    By b16 will in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th October 2009, 13:57
