AH FabricationsChris Nott
Results 1 to 16 of 16
Thread: Drive By WTF?
    Monster
    Oct 2013
    South West UK
    16
    Talking Drive By WTF?
    Hi everybody!
    So, this is my B6 -
    Obviously wants to be lower, and maybe someone can tell me if I can use sport springs with SE shocks?
    But what I really want to know is - is there a way to speed up the DBW response? Particularly when going from full throttle to lifting off, the throttle doesn't respond quickly enough to make fast, smooth changes.
    I've replaced the clutch switch. Twice. No difference.
    How about the throttle body motor. Anything should be done to free it up?
    Or how about re-setting the ECU? Is that likely to make any difference, and can I do it by just pulling the fuse? If so, which one?
    I drove a 2012 Golf today and that was similar, though not as bad so maybe that's just how DBW is and I'll have to get used to it. If that's the case I'm surprised they didn't stick with cables! It can't be doing the clutch any favours...
    Anyway, thanks in advance for any information/advice.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    no real change you can do except get it remapped to improve throttle response
    Sep 2013
    Portsmouth
    245
    You can also get DT-UK peddle box
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,341
    Sprint booster is supposedly decent too, all seem very overpriced though.
    Monster
    Oct 2013
    South West UK
    16
    Yeah, they seem pretty steep. If this is how Audi intended it to be I can put up with it for now. No point re-setting ECU then?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Have the ECU read for any DTC's.....might be something underlying.......
    2002 2.5 V6 Quattro
    Mar 2012
    57
    You can reset the DBW very easily.
    1. Get in your car, it doesn't matter if you close the door or not.
    2. Turn the key to the on position, the position just before the starter turns over.
    3. Press the gas pedal to the floor with the key in the "on" position.
    4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position(don't remove the key), then release the gas pedal.
    5. Wait 2 mins. for a full alignment. During this time you may hear very faint noises and clicks. I
    only heard one sitting in my car, if I got out and popped the hood I might hear more.
    B6 A4 Easter Eggs! Features not found in the owner's manual. - Page 7
    Monster
    Oct 2013
    South West UK
    16
    Thanks, I have tried that, but have not noticed any improvement. Should I disconnect the battery instead? Would that clear the ecu?
    S4_dan's Avatar
    Jan 2006
    1,600
    Get the codes read to see if there is underlying fault rather than just guessing!!!
    Buy a cheap lead from ebay and use VCDS or go to a vag garage.
    2002 2.5 V6 Quattro
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Is this a petrol or diesel?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    S4_dan's Avatar
    Jan 2006
    1,600
    Quote Originally Posted by jdp1962 View Post
    1984cc Petrol.....
    2002 2.5 V6 Quattro
    Monster
    Oct 2013
    South West UK
    16
    Dan is on the money. I certainly will get the codes read when it's in for servicing. In the meantime I would be interested in hearing if anyone has had any improvement in throttle response from an ecu reset.
    Also can I use sport springs with se shocks?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Gurner View Post
    Yes, although they'll be used in a lower position of their travel, so they might suffer a reduced life, but they will be fine in the short term.
    pauldazzle's Avatar
    Cardiff
    636
    Check that the clutch pedal switch is working with VCDS. If it fails the rpms are slow to drop on gear changes.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    So what does this achieve?
    Quote Originally Posted by s3tby View Post
    *WANTED* AUDI CD PLAYER
    S4_dan's Avatar
    Jan 2006
    1,600
    Quote Originally Posted by DALE_AVANT View Post
    Throttle Body Alignment....look up on Ross-Tech site for ins and outs
    2002 2.5 V6 Quattro
  1. theory driving test. WTF?
    By ScottD3 in forum General Automotive Chat
    Last Post: 26th October 2011, 21:21
  2. Seating position when driving fast. Turnfast web
    By rodfj in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2009, 19:02
  3. Fun drive.
    By mramage in forum Other Brands & Models
    Last Post: 15th April 2003, 15:13
  4. Today's S3 drive - Buxton reccy
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2003, 17:10
  5. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
