Chris NottAH Fabrications
    davidfox280585's Avatar
    Aug 2009
    108
    a4 cab 2.5tdi vibration under acceleration
    i have a vibration under acceleration like the wheels arent balanced,
    ive had new wheels,
    new tyres and balance
    new offside shaft last year and that made no difference
    both inner cvs feel like they have slight play in but my mate reckons they are all like that,
    its really been doing my head in as its been like this 2 years now,
    if i shut off and coast its fine i took it up a notch on a open motorway early hours from work to 120 (as a test) i never speed to be fair but needed to check vibrations,
    anyway after 80 its gone
    could it be a slight misfire causing engine vibration?
    doesnt vibrate through the steering wheel but the gear stick shakes horrendous and you can feel it through the car
    any thoughts?
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    I would suggest another slightly bent driveshaft or the propshaft - could be an engine / gearbox mount?
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    glenandem's Avatar
    Sep 2012
    manchester
    529
    im having a very similar issue with my 1.9 tdi fwd 5 speed at the mo,my vibration comes mildly at 40ish but get really bad at mway speeds and i too can drive through it at about 90-100 mph, ive replaced both engine mounts and front snub mounting,ive replaced dmf and clutch so checked the rear gearbox mounting while i was there and that seemed ok but im thinking about replacing that as ive done all the rest!
    im pretty certain though its either a slightly bent driveshaft as theres no play in them and look straight enough jacked up or possibly a winky gearbox as passenger side driveshaft has play actually inside the gearbox when i rock driveshaft!
    my driveshafts both have a midges of play in the cv's too and im pretty happy that its acceptable too!
    if i find my problem i will post up what sorted it as ive found threads on here and other forums with similar vibrations and they never posted the fix!!
    Aug 2009
    108
    Been in it tonight as the mrs drives it and vibrated from 40 all way to 80 then gone,I also have play in the internal box like you,I will try to upload a video soon,its definately transmission issue may try 2 new inner cvs
  1. Strange vibration under full throttle acceleration. Any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 15:21
  2. Odd vibration when accelerating
    By Halgernon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2007, 00:11
  3. Surge under acceleration
    By Beef in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2007, 02:26
  4. Vibration under braking
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2006, 20:11
  5. Steering wheel vibrates under firm braking
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 21:15
