Sky InsuranceBadger5
Results 1 to 10 of 10
Thread: boot catch
    Audi!
    Apr 2013
    Kent
    55
    boot catch
    Hi all
    has anyone had trouble with the boot catch?
    Sometimes it wont shut, but thats rare. Generally, while driving the warning light comes on saying the boot is open.
    However the boot is well and truly shut. But when this happens, also the light in the boot comes on, and you also cant always lock the car until you open and shut it.
    Any ideas?
    Cheers!
    Audi!
    Apr 2013
    Kent
    55
    sorry - A4 estate 2004
    Aug 2011
    186
    Common problem. Try some spray lube into the lock - if that doesn't work then it's probably the micro switch in the lock itself. Lube worked for me - so far. Mike
    Audi!
    Apr 2013
    Kent
    55
    Cheers mike will try spray. If that doesn't work- maybe ebay!
    Dec 2007
    Brighton - well Hove actually
    71
    Ditto.
    I have problems shutting mine sometimes. If I close it gently its fine. If you slam it it bounces out. I replaced the solenoid but that hasn't helped. I Need a new boot lock..
    2.8 30V V6 193PS
    Gone. But not forgotten
    Now
    A4 2.5tdi 180 quatro
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Sounds the micro switch breaking down.
    Can you guys adjust your boot latch?
    Would that help?
    I'm on my 2nd boot latch, my micro switches keep going. I've given up and unplugged it.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,297
    Pretty sure this problem runs across the board too, mine's terrible and so is my friends A3 8L.
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    194
    Had this problem on my Golf GTI. Changed the micro switch which didn't solve it. It turned out the wires running between the boot and car were split!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Quote Originally Posted by DieselJake View Post
    Same as the rear wiper.
    Known issue for years and Audi has not done any thing about it.
    Audi!
    Apr 2013
    Kent
    55
    So a new catch prob won't cure it? Generally its just the light coming on and the dash display warning you. But the boot is shut. But when I arrive at my destination, I have to open and shut the boot or else the light stays on and sometimes the car won't lock.
    So if I take the latch out, unplug the micro switch, the boot still locks? Central locking etc?
    Saying that- this morning, the boot actually came open while driving. So if this happens a lot I guess its new latch time.
  1. Boot Catch Issues
    By Wizza in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2013, 21:56
  2. how to remove rear boot catch??
    By dancupra225 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2012, 22:15
  3. S4 boot catch
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th October 2009, 21:00
  4. Boot catch problem
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2009, 23:21
  5. A4 Avant Boot catch motor
    By lbaters in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2007, 15:03
