Volks AutosEM Tuning
Results 1 to 19 of 19
    Feb 2008
    Safe mode after earthing pin 1 for dis
    I have installed a dis wiper stalk to my b6 avant.
    I fitted the the stalk and the washer bottle warning came on.
    I then hen took the blue plug from the clocks and spliced an earth to pin on (brown and red I think).
    now when I start the car it will only run for 2 seconds and says safe under the speedo.
    Also all of the warnings for the sensors are showing.
    Could i have blown something when I earthed pin one?
    cheers
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    Have you tried removing the Earth?
    2009 A3 SB 2.0T DSG S line
    Feb 2008
    I've removed the earth but no change.
    Now the safe mode is gone and the car runs fine but I still have the screen wash, coolant and fuel warnings.
    Could i I have pulled the earths for the sensors out by misstake while messing around under the dash?
    Dec 2006
    barnsley
    927
    remove the battery and leave it off for 15 minutes and see if it resets itself
    if this doesnt work id be tempted to get it scanned and see if anything is showing up
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    are you really sure you got pin 1 ?<br>
    and was it the blub plug on the clocks ?<br><br>you say you slpiced into pin 1 the b6 doesnt normaly have a wire in there and you have to fit your own thats why i ask was it pin 1
    Feb 2008
    It was the blue plug with purple clip on the left of the clocks, looking from the drivers seat.
    Im sure it was marked as 1 on the plug and had a brown and red wire already in there.
    I will double check but I'm sure it was pin 1
    bez101's Avatar
    Jul 2008
    7,947
    sounds strange it went to safe when you earthed
    and went normal when it removed the wire
    when i have done a b6 and its had a wire and that was only once i cut the wire and earth i never splice into it
    Feb 2008
    Would it be worth me cutting the wire after the join so that the plug is earthed but the loom isn't?
    bez101's Avatar
    Jul 2008
    7,947
    make sure its number 1 first
    or take a pic of the plug and post it up
    Oct 2009
    Hull
    1,433
    I'm with Bez101 on this
    Pin one should be empty if you have a wire in it then this will go to the washer sensor if fitted if not fitted then you wont have a wire in pin 1
    check your work
    Feb 2008
    not the best pics but you get the idea. You can see a 1 on the plug.
    Im im sure it's pin one of the blue connector. There is a brown wire with a red tag in.
    I disconnected the battery while removing the plug and when I restarted the car it's back in safe mode too!
    Oct 2009
    Hull
    1,433
    hmmm pretty sure the numbering is on the cover and not on the actual plug!
    I remember when I did mine they was all numbered not just 1 of them!
    bez101's Avatar
    Jul 2008
    7,947
    on the ones iv done its had a number on each corner of the blue part
    take a pic with the cover on it
    or NHN may pop by to advise
    Feb 2008
    I will double check the numbering on the blue plug but I'm sure it said that the pin I spliced was number 1.
    Ive found a couple of post where people are have similar problems and it's the blue plug not pushed in fully or the green one has come loose while working under the dash.
    Could it be something as simple as that or maybe a bad earth?
    Oct 2009
    Hull
    1,433
    yeah thats exactly how I was thinking it was
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    As above.......sounds like wrong pin hole
    Mike
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    When i did mine there was deffo numbers on the blue plug albeit they where v small and there was no wire in pin 1. When i put the plug back in it didn't seat properly and i had all sorts of warnings flashing up,oil, brakes everything. Unplug and reseat and everything was good
    Feb 2008
    I'm officially a numpty!
    it was that the plug wasn't fully home.
    All working now.
    mattyboyc's Avatar
    Sep 2009
    1,167
    Quote Originally Posted by typertony View Post
    All working now.
    Glad your all sorted now, i have been following this as i have had all the parts to do this mod for ages now and i really must get on and do it.
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
  1. safe/limp mode after hard driving?
    By Phil_H in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2011, 20:22
  2. SAFE MODE STILL ... My results after a few tests !
    By GavConner in forum In-Car Entertainment
    Last Post: 30th July 2008, 15:08
  3. Audi concert stereo safe mode! Help!!
    By petephoenix in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2006, 19:32
  4. Arggghh RADIO showing SAFE mode!!
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2006, 21:11
  5. radio in safe mode , label help
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2005, 08:55
