Results 1 to 11 of 11
    Jul 2013
    70
    plenum grommets and air leak from same area?
    so got into car today and some water in passenger foot well not alot so far, so investigated and can see water and some corrosion under batter so can presume grommets never removed which im surprised by as previous owner has a full audi main dealer history from new till i bought it two months ago, but while investigating this i could hear an air leak in area around pollen filter but sound like it was either under water or spitting out liquid ill get better look tomorrow but any ideas?
    Sep 2012
    LEEDS
    115
    Take the battery/tray out and just pull the grommets out (on under the master cylinder too), I am sure there was a conspiracy at audi once upon a time as regards to these grommets . The damage and hassle they have caused is un-believable.
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
    Jul 2013
    70
    im going to that tomorrow any ideas but air leak sound?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    Quote Originally Posted by ei2gfb View Post
    Maybe vacuum leak from master cylinder or pipework?
    2002 2.5 V6 Quattro
    Jul 2013
    70
    my spelling is horrendous tonight.., ill check it all out tomorrow hopefully something simple, i did notice alot of rust so ill try strip it back and put a coat of iron oxide onto it and spray it back black
    Jul 2013
    70
    cant get near allen key or hex bolt to loosen battery there is a thick insulated bit the runs along the front of the battery which i presume olds the ecu cabling but also the nut looks corroided to pieces
    UPDATE: managed to remove some more trim and got down to bolt its completly rung someone has had a right good go at it before, i managed to unblock the drain hole under battery from below and a good 2l of water drained however id like to get to other one near master cylinder but removing the battery bolt is going to be a *****
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    I did both from under the car with some long reach pincers as o struggled to even get the battery out
    Jul 2013
    70
    i tired to feel for other one but couldnt feel it, is it under the master cyclinder, i tired to feel around there but the exhuast heat sheild blocks access
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,412
    I only have the one under the battery removed and all has remained dry in there
    Mike
    S3 GAZ's Avatar
    Dec 2006
    299
    Yeh its under the master cylinder. Much easier from below. Well untill you get 2lt of freezing water in your face
    Sep 2012
    LEEDS
    115
    One should be sufficient but two would be ideal ?
    Also the big trunking at the front does hold the cables and just unclips you have to be a little assertive with it but it simply unclips towards you (if i remember correctly ) also drying the carpets the easy bit however drying the insulation underneath is a absolute mission.
    Hope this helps ?
  1. A3 1.6 Sport 1999 misfire and air leak?
    By z3ph11 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2013, 17:22
  2. Syncing iPad and iPhone from same account but want different things.
    By Kaibo in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 18th February 2012, 09:56
  3. turbo problem air leak and breather valve fault
    By 10blazin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th March 2009, 18:23
  4. remap and leak from rear coolant flandge
    By justintime1026 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th November 2008, 18:01
  5. oil leak from an EGR Valve and poor starting - related?
    By chill14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 20:10
