Volks AutosJMB Retrofits
    jamesey's Avatar
    Sep 2013
    derbyshire
    92
    my car is knocking on the front end for some reason
    hi as above ive checked the linkages and the only ont that looks sus is the little u shaped one at the back of the front wheel , would this cause any knocking , it also knocks when turning the steering wheel off on my drive.
    Aug 2008
    Leeds
    152
    Could be allsorts of things..
    Bit of a stab in the dark but my exhaust mid-section worked loose today and the resultant drop of the front end of the pipe caused it to collide with the suspension arms at the front of the car, causing a loud knocking sound whenever I turned left.
    Is your exhaust fitted completely snug and where it should be?
    Just a thought...
    J
    2003 A4 B6 1.9 TDi 130 Quattro Sport
    2007 A4 B7 2.0 TDi S-Line Cabriolet
    jamesey's Avatar
    Sep 2013
    derbyshire
    92
    no idea to be honest ive not been underneath it yet , this weekend will see lol
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    Could be the front ARB bushes or the top suspension arms. If you're changing the ARB bushes, then definitely change the drop-link component (the one you described)
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Andie0's Avatar
    Aug 2012
    487
    Most probally drop links as said, does it happen when turning or just over bumps amd stuff
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
  1. MECHANICS PLEASE.... Knocking on the back end
    By weela89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th May 2011, 19:47
  2. Is the front end the same on a B7 cab and saloon?
    By dhillon884 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2010, 18:17
  3. Tarted up the front end
    By norm29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2009, 13:36
  4. Knocking from the front during gentle braking ???
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 22:29
  5. Knocking on the front suspension !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2007, 10:26
