Badger5Monster Motorsport
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    2 faults on vagcom found what are they?
    hi ive got round to doing a scan on vagcom instead of my little orange scanner and its come up with loads of faults ive cleared them all but 2 come back...... ive got
    00819 high pressure sensor G65 07-00 signal too low &
    01134 alarm horn H12 49-00 no communication? where is the alarm horn located on a b6? cheers
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Does your Aircon work? If so, don't worry about the G65, it's the sensor on the front condenser.
    The siren is in the boot, on the offside behind the amp.
    Audi A4/B6 Alarm Siren - Replace NiMH Batteries
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    no my air con doesnt work the econ light stays on , also would new batterys sort my problem out? is it easy to get to? cheers
    Mar 2008
    Dorset
    13,856
    It's fairly easy to get to, remove the boot hooks, remove the offside trim, remove the amp, and then siren is in there. The only weak link tends to be the batteries, but obviously I can't say whether they will cure your problem.
    AC sounds like a dodgy pressure sensor then.
  1. B8's H&R's etc - What are they worth?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2008, 20:47
  2. What are they worth??
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2007, 11:58
  3. A3 18" 20-spoke alloys - what are they worth?
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2007, 17:15
  4. MOT tomorrow, what are they going to try and scam me with?
    By FrankScorpio in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2007, 18:37
  5. Audi Alloys (What are they Worth? )
    By Wish in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2004, 16:05
