    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    can i do a speedo head test with the vagcom ive got?
    hi ive got a blue lead from ebay and its using vagcom i think its 4.09 version maybe?
    im wanting to do a speedo head test to check my temp gauge also alter my key to work the windows and chirp the alarm etc , can this be done?
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    someone must know?
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Go into 01 Engine, then Measuring Blocks and go up through the numbers and find the coolant temp one. If it shows 90 degress and your gauge shows nothing, then you know it's the gauge.
    The windows, you need to go into Central Convenience I think then adaptation... I'm not sure of the specific coding bt lookon the Ross Tech site as it has all the instructions.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    If you want to check if your instrument is working you do this by going into 17-instruments and then click on output test and it will go through different stages.
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    when i press output test it come up with a warning about registration , ive got a ebay blue lead , whats all this about a black lead with a chip inside?
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    The leads with the chips inside are official Ross Tech leads. As you have a copy lead, Ross Tech allow you to use VCDS Lite for "testing purposes" and offer no support. As your lead appears to work you can register VCDS Lite for approx £70 and this will give you Auto Scan, Coding & Adaptation and Output Test functions. Check out the Ross Tech website for the full list of what you can and can't do.
    A4 Avant 1.9 TDi Sport GmbH
  1. Can I use my VAG-COM cable with the neighbours BMW M3?
    By _G_ in forum General Automotive Chat
    Last Post: 22nd March 2013, 12:29
  2. can i do a leak test with an air compressor?
    By John Spooner in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2012, 10:51
  3. can i do this with the vagcom lite
    By skinz in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2011, 16:46
  4. Wot to do with the engine Ive jus bought ????
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2011, 21:28
