Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    Oct 2012
    434
    1.9tdi mpg gone down now it's colder
    Has anyone else noticed this? i have been getting easily mid 50's now am down at 49-51mpg, oddly enough the hotter the outside air temp over the summer the better mpg i was getting. is this normal with diesel's?
    Ta
    May 2012
    RETFORD, NOTTS
    1,753
    Rain = drag and extra wieght on the tyres... could explain why im seeing 46 not 56 now...
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    2,180
    Yes very normal, colder air is denser so the engine uses more fuel to compensate but you should get a little more power, but won't be that noticeable
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    It's actually due to the anti freeze additive the refinery add the stop diesel slidifiying, this reduces the cetane rating thus MPG slightly drops.
    Jul 2007
    London
    3,255
    Not entirely true, cold weather the engine uses more fuel to get to operating temperature hence the Mpg drop. Winterized diesel is not introduced till late november if the weather forecast is well below zero celsius.
    FOR SALE:
    Oct 2012
    434
    Time to compensate with some additive then.
    Sep 2009
    Rumburgh Suffolk
    193
    Quite natural, stop worrying, the colder the engine the more fuel it will use till up to temp, plus extra electrical loads etc.....
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    glenandem's Avatar
    Sep 2012
    manchester
    531
    yep mine went down from averaging 39-40 in the summer to 34-35 last winter with the snow but just this last week ive noticed its gone down to 38 so its dropping with the temp!
    Oct 2012
    434
    Wow never thought it would make that much difference, it's like 10% or so
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,618
    So would adding a cetane booster to the fuel make much difference?
    2002 2.5 V6 Quattro
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,354
    From my experience it just provides a placebo effect.
    May 2012
    RETFORD, NOTTS
    1,753
    I put a can of injector cleaner from kwik fit through it yesterday and im back up to 56mpg :D
  1. A3 sportback 1.9tdi MPG
    By maxlbrown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1 Week Ago, 17:55
  2. My G/S have gone down again! FFS now what!?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2011, 11:12
  3. VAG COM fault code readings... possible coil pack gone down?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th March 2010, 16:47
  4. 1.9TDI water pump problem, now non starter
    By kitefright in forum Diesel forum
    Last Post: 20th June 2009, 18:52
  5. Has A Silver S3 Gone Exclusive Now?
    By a3norwich in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2007, 12:34
