Volks AutosAH Fabrications
Results 1 to 8 of 8
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    cant get heater to blow on windscreen on my audi a4? and econ problem
    hi ive just checked the heater controls and ive got a couple of probs , if i go through the buttons it blows on feet and face vents then moves to windscreen but doesnt blow through the vents i can hear it blowwing near the top , could it be a link that has come off.
    also my econ button is on all the time when i press it the light goes out but comes back on again , i dont think my a/c works?
    here a pic of what sort it is,,,,,,,,,,can you go into settings etc20131012_170100.jpg on these like the passat b6 controls?
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    my ign had just been turned on thats why the light isnt on lol
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    There's no self diagnosis option on the B6 I don't think. If the ECON light remains on it means the compressor is of, ie the AC system has isolated it due to a fault, maybe just low gas.
    The demist fault is down to a sticky mechanism/solenoid, I posted the repair thread in answer to your other question.
    HELP! windscreen demister
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    cheers bud , ill be looking tomorrow.
    Greeny233's Avatar
    Mar 2011
    Llangollen
    703
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Having the same problem myself. I removed the solenoid motor and stripped it and re-greased it but it made no difference so I ordered a second hand control unit which made no difference :o( think I'm going to try replacing the solenoid with a new one (£175 + vat from Audi) or a second hand one.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Mar 2011
    Truro, Cornwall
    62
    I had the same problems when I bought mine. The flaps had stuck on mine and didn't direct any air to the windscreen, take all the glovebox bits out and have a look, you may be lucky like me. Haven't had a problem since. My econ light on was the sensor located in the air con rad just by the passenger headlight. Replaced that and all was good. About £50 for the part.
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    took the glove box out i found the windscreen motor stuck and the recirc one shut aswell that also wouldnt shut or open , no wonder it was steaming up , i took them off greased and hey presto all works again , apart from the aircon ,
    i looked on vagcom and the air con came up with a high pressure sensor (g65) , does this sound simular?
    Mar 2011
    Truro, Cornwall
    62
    That's the fault mine was showing, but apparently shows if the system needs re gassing as well. I would edge my bets with the sensor, it's easy to fit, took me about 15 mins to do and doesn't cost too much, about £50.
  1. Replies: 11
    Last Post: 9th February 2007, 18:34
  2. Cant get HU out!!
    By imported_Gibbsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2004, 11:34
  3. Cant get a reading from my car
    By shamtec in forum General Technical / How To
    Last Post: 16th October 2003, 22:31
  4. Cant get a diagnostics from my car
    By shamtec in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2003, 13:37
