Sky InsuranceEM Tuning
    Oct 2013
    108
    No dash illumination or climate control
    Evening, just wondering if anyone has suffered temperamental lack of dash illumination as well as climate control only working when set to the front windscreen? It's annoying when it's only sometimes and I'm not sure the best order to check things in.
    Many thanks in advance
    Oct 2013
    108
    Right, read fault codes on this and at the most the climate control has come up with the fault that it is not ready sometimes, but no codes specifically about the dash illumination not working.
    I find it tends to happen more when I've left the car unlocked for a time whilst washing it and then go to drive it, so it could be related to waking certain modules back up. Anyone else had this issue?
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    766
    Sorry Moo, not something I've ever experienced. Hopefully someone else 'round here can help you get it sorted.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Oct 2013
    108
    Afternoon!
    I had a bit of time last weekend to remove my dash pod and disconnect the connectors, then reconnect them. No corrosion but I did it on the off chance that was the issue. I'll get some stereo keys soon too to re-check all of the connections behind there because at some point it was all removed to fit a Parrot kit. For now it's been ok though.
  1. Clicking noise behind climate control dash
    By xyz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2011, 12:10
  2. Facelift dash single to double DIN climate control question
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2010, 18:58
  3. Audi A3 Climate Control
    By ramstein666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 20:18
  4. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
