Volks AutosChris Nott
Results 1 to 22 of 22
Thread: vcds coding
    Oct 2011
    22
    vcds coding
    Hi I'm having an issue with the soft coding for the central convenience (46) module.it keeps showing 00000? Have tried different code ilexa said to try but no joy.I do have full vcds.
    Any ideas??
    Car Audi a4 2001- (b6)
    Cheers chris
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2011
    22
    Hi,cheers for reply,I've generated a code from that page it just doesn't store it!!was thinking ccm might have a fault.
    Do you know if you have to have the exact matching module or will any b6 do?
    Thanks Chris
    Sep 2013
    Portsmouth
    158
    Are you using a genuine interface and software?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    Quote Originally Posted by audi-nutz View Post
    Thanks Chris
    get same part number
    what have you got now ? and what was fitted before you swapped out ?
    Oct 2011
    22
    06273
    The code i was told to enter was 06273 which apparently is the standard code for my car! Is it just a case of entering code and leave wsc at 00000 then click do it?or is there a login like some of the other modules?
    Yes it's genuine vcds software and cable.
    Cheers Chris
    Lancaster
    1,629
    Change the WSC to 12345 and try it.
    To do: None yet.
    Oct 2011
    22
    Cheers for suggestion have already done that one with no luck. Do you think code not sticking is down to faulty ccm?
    Lancaster
    1,629
    What partnumber prefix is it giving?
    To do: None yet.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    6273 is a strange code IMHO:
    4096 = Thatcham alarm
    2048 = Electric windows
    128 = RHD
    1 = GB alarm
    That leaves out several settings that are "normal"?
    Oct 2011
    22
    The original code was a fair bit higher but was advised to start with a basic one and then add options. Anyway neither has worked. Have managed to source another ccm today hopefully that will sort it.
    Lancaster
    1,629
    What part numbers?
    To do: None yet.
    Oct 2011
    22
    Ccm 8E0 959 433 AC
    Lancaster
    1,629
    Can you post the scan data?
    To do: None yet.
    Oct 2011
    22
    Saturday,12,October,2013,21:27:55:52763
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WAUZZZ8EZ1A022192 License Plate:
    Mileage: 229770km-142772mi Repair Order:
    Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8EZ1A022192 Mileage: 229770km/142772miles
    Address 01: Engine Labels: 06B-907-557-ALT.lbl
    Part No SW: 8E0 907 557 HW:
    Component: 2.0L R4/5VS 0005
    Coding: 0011501
    Shop #: WSC 63351 000 00000
    VCID: EED51287FA599E6EF6F-5178
    1 Fault Found:
    16804 - Catalyst System; Bank 1
    P0420 - 001 - Efficiency Below Threshold
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front D620
    Coding: 04275
    Shop #: WSC 12345
    VCID: E5C76DAB7FAF5D36875-515A
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0406
    Coding: 00000
    Shop #: WSC 63351
    VCID: DEB542475AF90EEE46F-515A
    1 Fault Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-00 - Open or Short to Plus
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00000
    VCID: 346140EF04F574BE40B-4B32
    2 Faults Found:
    00984 - Left Tail Light (M4)
    57-00 - Electric Circuit Failure
    00985 - Right Tail Light (M2)
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    VCID: F4E100EF9475B4BE00B-515A
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0102
    Coding: 00011
    Shop #: WSC 63351
    VCID: 36657AE7128966AE7EF-4B32
    3 Faults Found:
    01333 - Door Control Module; Rear Left (J388)
    49-00 - No Communications
    01334 - Door Control Module; Rear Right (J389)
    01330 - Central Control Module for Central Convenience (J393)
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 D
    Component: KOMBI+WEGFAHRS. RB4 D10
    Coding: 00400
    Shop #: WSC 01234
    VCID: 2A5D5E97D631324EEA7-515A
    WAUZZZ8EZ1A022192 AUZ6Z0Y0034563
    2 Faults Found:
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0403
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD31B93994B6B46D11-5120
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 K
    Component: Komfortgerát T01 0313
    Coding: 00000
    Shop #: WSC 00000
    VCID: 397F71DB239789D693D-4B18
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 4.11
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 4.11
    Subsystem 3 - Part No: Steuerger
    Component: t HL antwortet nicht
    Subsystem 4 - Part No: Steuerger
    Component: t HR antwortet nicht
    3 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186
    Component: concert II GRO 0001
    Coding: 00001
    Shop #: WSC 63351
    VCID: E4C170AF7495243E90B-4B00
    1 Fault Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    36-00 - Open Circuit
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    THat log looks very strange - why are door control module faults showing against multiple controllers?
    Have you tried clearing all the DTCs on all controllers?
    The most worrying DTC is the "01366 - Opened due to Crash Signal" - combine that with the strange message from the airbag controller and I suspect that the car has been in an accident serious enough to deploy the airbags and unlock the doors. Do you know the history of the car?
    Oct 2011
    22
    Hi Dave, ye have cleared codes a few times then go to open car in morning and get a small clicking sound like it's trying to unlock but can't.once I drive car things tend to work somewhat. As for crash signal fault I've owned car for 6 years and aren't aware of any previous on it. I was a little baffled by the cat code as that's a new one.
    Cheers chris
    Lancaster
    1,629
    Have you run a sequence test on vcds?
    To do: None yet.
    Oct 2011
    22
    Blackquat how would I run a sequence test?each module individually?
    pauldazzle's Avatar
    Cardiff
    553
    Cheers Chris
    Try logging in first 12233.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Oct 2011
    22
    Will do that,cheers Paul.
    Oct 2011
    22
    Login code did nothing,have managed to source another ccm and all seems to work.
    Thanks to all for suggestions.
  1. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th April 2010, 07:38
  2. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2010, 17:58
  3. VCDS coding for tails
    By tcardio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2010, 17:45
  4. Help! Passenger's window won't close! VCDS Code.
    Last Post: 3rd January 2010, 01:07
  5. VCDS Codes
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th December 2009, 13:01
