EM TuningSky Insurance
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    DTC Fault codes dilemma
    Hi, Newly purchased 2.5Q had some DTC's stored. I wasn't sure how long they had been there so I cleared the fault codes last week and gave the car a run for a few days and scanned again. Here is the list:
    VCDS-Lite Version: Release 1.2
    Wednesday, 09 October 2013, 10:18:01:37918
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: 059-907-401-AKE.LBL
    Controller: 8E0 907 401 D
    Component: 2.5L V6 TDI G000SG 0009
    Coding: 02015
    Shop #: WSC 63351
    VCID: 263FE185D1FF
    00005059 130 106LC150_1.V79450931286
    4 Faults Found:
    17978 - Engine Start Blocked by Immobilizer this is a new code
    P1570 - 35-00 - -
    P1570 - 35-00 - -
    18057 - Powertrain Data Bus: Missing Message from ABS Controller this code was present before
    P1649 - 35-00 - -
    18062 - Please check DTC Memory of Instrument Cluster this code was present before
    P1654 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04455
    Shop #: WSC 00011
    VCID: 263FE185D1FF
    1 Fault Found:
    65535 - Internal Control Module Memory Error this code was present before
    00-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 L
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    VCID: 2A2715B5C5E7
    1 Fault Found:
    01809 - Actuating Motor for Temperature Flap; Left (V158) this is a new code
    41-10 - Blocked or No Voltage - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Controller: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 63351
    VCID: 341B0BCD1723
    1 Fault Found:
    01312 - Powertrain Data Bus
    79-10 - Please Check Fault Codes - Intermittent this code was present before
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 JX
    Component: KOMBI+WEGFAHRS. RB4 D38
    Coding: 01400
    Shop #: WSC 00001
    VCID: 88630F3DBB2B
    WAUZZZ8E83A1***** AUZ6Z0B01*****
    2 Faults Found:
    01176 - Key
    07-10 - Signal too Low - Intermittent
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent this is a new code
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8E0 959 433 BC
    Component: Komfortgerát T3B 1110
    Coding: 07115
    Shop #: WSC 63351
    VCID: 7399C8D152AD
    3 Faults Found:
    01134 - Alarm Horn (H12) this is a new code
    29-00 - Short to Ground
    01370 - Alarm triggered by Interior Monitoring this is a new code
    35-00 - -
    00962 - Alarm via. Tilt Sensor this is a new code
    35-00 - -
    End --------------------------------------------------------------------------------------------------
    The alarm codes I am not phased by, I will be doing a siren battery repair on mine and my dad's S8 soon.
    However, worryingly, some DTC's have returned that were there before I cleared them, all relating to the ABS module. Assuming this is duff ABS and needs replacing? Although, I have no MIL or ABS/TC dash lights on??
    Some new codes had arrived too. Just my luck.
    HOWEVER, under the drivers floor mat......the carpet is WET!!! So where would be the first place to look? I can't do anything until the weekend, when I will be doing a Mr Muscle job on the turbo anyway.
    Any pointers on the above would be greatly appreciated. (I've taken on-board about comments in other post too)
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,730
    Check the ECU seal around the ECU box if the carpet is wet on the drivers side.
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    As above but also remove all the relays, etc in the ECU box to check for corrosion as you have the classic water ingress faults ie comms lost
    A4 Avant 1.9 TDi Sport GmbH
    jamesey's Avatar
    Sep 2013
    derbyshire
    90
    i agree i took 10 litres of water out of mine , the seat will have to come out , trims off and pull the carpet up to get wet vac in and then foot heater. fix seal first mine had fell into the car for some reason
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
