AH FabricationsVolks Autos
Thread: temp sensor
    Apr 2011
    160
    temp sensor
    Can anyone tell me what the temp sensor located on the bottom rad hose is for and what issues arise from it?
    Its showing up as open circuit on the fault code list.
    Its a 1.8t avj
    Apr 2011
    160
    Anyone
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    its to tell the ECU the temp
    if its showing a fault check wireing or change it
    what code did you get ?
    May 2013
    7
    I just went through this with my 2004 A4 1.8T. Ended up replacing both the thermostat and temp sensor.
    I had just recently replaced Timing Belt and WaterPump - then temp gauge started having intermittent fluctuations - from mid range to cool. Never overheating.
    The fault codes I got were: 17700 - P1292 004: Map Controlled Engine Cooling Thermostat F265 Open Circuit; and 19497 - P3041 004: Databus drivetrain implausible engine temp messaging from instrument cluster.
    Hope that helps.
    Apr 2011
    160
    Cant remember the code. Just remeber I pointing out was the temp sensor on the lower rad hose. I just interested to know if it will directly effect fueling as its not running overly efficient just now. Also would it effect emissions as mot just around the corner
    Apr 2011
    160
    Also that reads as though im either pissed or stupid haha auto correct at its best
  1. Coolent Temp Sensor...
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 13:13
  2. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  3. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  4. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  5. S3 Temp Sensors
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 16:53
