Monster MotorsportChris Nott
Thread: late boost?
    Jan 2013
    Northern Ireland
    71
    late boost?
    Hey all, hope someone can shed some light on this. Today my car was going perfect until I washed underneath is for the MOT which is now on Friday. But since that there is now a boost/turbo problem. The car has no power at all or very little at least until you reach about 3k revs, normally the turbo kicks in at 1500k. its a 1.9 tdi 130 sport. when you do take it past the 3k revs, its normal with animal type power but dead before it. I took the MAF off just to test, made the car even worse, couldn't get up past 40mph. Checked all pipes underneath the car, no splits or air leaks can be seen or heard. Anyone got any ideas?
    p.s just remembered, I took both head lights out to take the HID bulbs out and replace normal bulbs, unless there is something possible in the drivers side I touched? Initial looking seems that everything is connected.
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Yes there's a black box by the drivers side head light just below it and the pipes run close to the head light maybe you moved them or
    something Sound like a loose pipe therefore lack of boost
    good luck m8
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. turbo boost?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 14:06
  3. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
  4. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
  5. Late Christmas present for my S4.
    By JohnH in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2003, 10:21
