Monster MotorsportVolks Autos
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    535
    air con pressure sensor
    Still having probs...
    A while ago i finally got the correct sensor.
    Installed but the econ button still wouldnt turn off!
    Got it scaned and still says fault is pressure sensor??
    Wtf...
    It new from audi and is the correct part.
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    glenandem's Avatar
    Sep 2012
    manchester
    457
    have you got enough pressure in the system?, had it regassed lately?
    also on mine i found the terminals in the connector had gone slightly rusty so had to clean them up but yours could be a possible wiring fault?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    535
    Had it regassed a couple of times now,each time no change in temps.
    Il have a look at contacts later,cheers.
    Lancaster
    1,636
    What is the fault showing?
    To do: None yet.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    535
    Didnt get the numbers but he showed me on the laptop...
    Aircon senor fault,g65 or somethink.
  1. Air Con Pressure Switch - Where From?!
    By Veero in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2013, 17:51
  2. Air Con Pressure Temp Sensor location
    By johno5 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 8th May 2013, 20:37
  3. Air con pump sensor
    By Jab XL in forum Air Conditioning
    Last Post: 23rd November 2012, 17:11
  4. air con pressure sensor
    By wayne77 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th July 2012, 19:42
  5. Too much air con pressure
    By sworks16 in forum Air Conditioning
    Last Post: 24th August 2008, 08:39
