Chris NottMonster Motorsport
    Jun 2009
    60
    2.5 TDI Turbo Question
    Hi
    I think the turbo on my Quattro 2.5TDI is on the way out -- I can deffo hear a "new" noise, slightly higher pitch
    anyway, what model is it -- a quick glance on Ebay seems to suggest it is a Garret T3 and lots for sale - is that correct?
    does anyone know the exact model number (I have a MY2002)
    also has anyone fitted one, any gotchas special tools etc
    thanks in advanced
    Sep 2012
    LEEDS
    116
    3 bolts on the heat shield
    3 bolts on the hot side attaching it to the pre cat.
    Jubilee clip on the air side (if i Rember correctly )
    4 bolts attaching iot at the base be carefull as you dont want to round them of as i did with one ( causing no end of problems )
    I did my own when it went and once i took the heat shield off it was relativly straight forward .
    I just had a problem with the setting up so had to get adamss24 to sort it out properly as the boost was lacking when going up steady inclines .
    mines a A6 2.5tdi AKE so may be diferent and alittle more spacious under the bonnet if yours is a A4 ?
    Wd40 or heat gun at the ready.
    Read it for codes first though to save costs if not needed ?
    Or try the Mr Muscles idea ?( google or search on this site )
    Good Luck
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
    Jun 2009
    60
    Quote Originally Posted by gtiboy View Post
    Good Luck
    thanks GTIboy
    mine already lacks a bit of boost when on a steady inclinec - LOL
    and I have tried the Mr Muscle trick
    it still drives fine TBH (really well, apart from the odd boost issue), but I just think the Turbo is on the way out, it has done 165K
    Jul 2007
    London
    3,074
    The turbo is a gt2052v and whilst widely available there are a few different versions fitted to different power variants. If you need i have a good one off a a6 tdi quattro sport, drop me a pm if interested !
    FOR SALE:
    Sep 2012
    LEEDS
    116
    Adamms is your man .
    Well worth the long drive to go see him
    Jul 2007
    London
    3,074
    Thanks Satty, i do my best mate to look after people ! Cheers !
    FOR SALE:
  1. tdi 140 hybrid turbo questions
    By nickmc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2013, 11:56
  2. A3 Tdi TURBO Question
    By Mackers in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2012, 18:20
  3. 2.0 TDi Turbo question
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th September 2011, 18:15
  4. TDI 140 PD turbo questions
    By heyadamhey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2010, 18:17
  5. A4 turbo question
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2003, 18:47
