Chris NottEM Tuning
Results 1 to 18 of 18
    Oct 2013
    13
    Headlight problem
    Hi guys.
    Ive very recently bought A 2002 Audi a4 with angel eyes , I'm not sure if xenon or not .
    drivers side works perfect but the passenger side is dimmed halfway , so only the bottom half of the two angel eyes on the passenger side is lit.
    i don't have much experience with cars but my guess is that this is due to a bad ground.
    Just wondering if any of you guys had the same problem or have any idea on how i would go about fixing this.
    Thanks.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,091
    If it's got HID's it'll more than likely be a problem with those rather than the headlights. Just look for a box behind the headlights, probably best to swap it with a decent kit.
    Oct 2013
    13
    Quote Originally Posted by DieselJake View Post
    Hi , thanks for the reply , ok ill look into that today after work , maybe i can fix it myself.
    but if it was a bad earth where would i look for the earth cable on an audi ?
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    766
    I don't think there's many people on here running aftermarket angel eye headlights to be honest, so you could struggle to find someone with the same issue.
    Maybe you could plug the dodgy headlight into the good side just to check if it lights up properly there? At least then you'd know if it was the light or the wiring to the light. No idea if the plugs are the same on each side, but if not you've only wasted 5 minutes.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Oct 2013
    13
    Quote Originally Posted by SmoothAssault View Post
    Thanks ill try that too
    Sep 2013
    33
    Hi
    I've got angel eyes on mine. If yours are same as mine then you got 5-6 small bulbs going around. If any of them has come out you will have them looking as you described. Best to post the picture while lights are on.
    Oct 2013
    13
    Heres some pics, doesnt look like its working at all on the pictures but it is , its just faint.1374876_10151698345806947_1772295806_n.jpg1377358_10151698345721947_816684980_n.jpg1234717_10151698345931947_147367484_n.jpg
    Sep 2013
    33
    Hi... That looks same as mine. You need to remove the light out - 4 bolts. Once out open the back of light in question then check the 6 bulbs placement. You just need to push them back in place with screwdriver.
    Oct 2013
    13
    Quote Originally Posted by Google44 View Post
    Thanks for the reply , i tried that.
    the bulbs actually were out of place , so i put them back , but its still alot less lit then the other side , i dont know what to do .
    how would i check for a bad ground or so ?
    Thanks.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    Quote Originally Posted by ALFAAA View Post
    Thanks.
    Find the earth wire on the light connector and add another piece of wire to earth. Usually there is only one earth at the connector, so if the other light functions (indicator etc) is working fine then try changing the bulbs for new ones. or swap with the other headlight and check again.
    2002 2.5 V6 Quattro
    Oct 2013
    13
    Hi guys i have just installed HID's and you can clearly see that one side is brighter im wondering if any1 could explain the rewiring of the ground in more detail?
    thanks.
    Dec 2007
    Cambridgeshire
    766
    Could be a faulty ballast. Try swapping it onto the other side and see if the issue moves with the ballast.
    Oct 2013
    13
    it was the same with my old bulbs. , started this thread awhile back
    Sep 2013
    33
    Did you try to power it up while you look at the back of the light? If same as mine then you should have a number of small bulbs going around the ring. One of them may be gone? Also, bulbs have someting on the top to protect the light going out. I've replaced them on mine with bulbs I've found in old cars dashboard. Not sure what type they are but when you remove them you will know what I am talking about.
    Oct 2013
    13
    Yea some of the angeleye lights were loose , ive put em back in the place , theyre all working , see its not just the angeleye rings anymore , its the hid aswell so from what i can tell the whole light unit is underpowered on one side and im trying to find a way to fix that .
    Sep 2013
    33
    I've got HID on mine too. Why don't you swap the HID power pack only on two side or even swap the HID bulbs. Have you got a pic?
    Dec 2007
    Cambridgeshire
    766
    Well then it's pretty safe bet that the bulbs aren't the problem. You need to narrow down the issue and the only way to do that (without unnecessarily spending money) is to swap things around between the working side and the faulty side.
    My HIDs did exactly the same thing, I thought a bulb was faulty but before buying new ones I swapped the ballasts around. Turned out the bulbs were fine and a faulty ballast was causing the bulb to appear dimmer. Ordered a pair of slimline ballasts instead, problem solved.
    S4_dan's Avatar
    Jan 2006
    1,504
    Have you followed the earth (brown?) wire from the loom on the dull headlight side? Could be a poor connection.
    Or try checking/replacing the light relay?
    Dan
    2002 2.5 V6 Quattro
  1. headlight problem
    By baedan in forum A8/S8 forum
    Last Post: 9th April 2007, 20:01
  2. headlight problems
    By garratt83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2006, 14:14
  3. Headlight Problems
    By cheekybee in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd January 2006, 19:19
  4. HEADLIGHT PROBLEM!!! HELP
    By jorgemiranda in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2004, 18:47
  5. Headlight Problem
    Last Post: 27th November 2004, 09:08
