    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    b6 avant water leak,,,carpets soaked arghhhh
    hi ive got a major problem with water entering my rear drivers side and soaking into the front , its not antifreeze or the pollen filter areas or the bulk head bungs.
    dont know if its this but ive opened the drivers rear door and the rubber seal on the door seems to be dripping like mad , has anyone any clues?
    Oct 2012
    429
    could be the water is not draining out of the bottom of the door and filling up inside, check the drain holes are clear
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    hi , well i took all the windscreen trim off and wipers etc etc and took the ecu housing out , can you believe the ecu foam seal was hanging inside the hole that leads into the car , i just noticed water running down my brake pedal thats why i took this off 1st , ive cleaned it around the seal ive turned the seal round and stuck it with gasket sealent this bugger shouldnt leak again ,
    after that i took the drivers seat out and the side trims and i couldnt believe what i was seeing it was a good job i borrowed the wet vac from work i must have emptied over 6 litres of water out , i vaccuumed the foam and left a heater in there all day until it was dry god know what my leccy bill will be lol , im just glad it was the drivers side not the passenger side.
    the only mistake i made removing the seat was i unplugged the plug under the seat without taking battery terminals off without realising it was for the seat airbag , will this be ok? cheers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    should be ok aslong as you havent turned the iggnition or
    or it will need a quick reset
    did you check the relays for water in them ?
    as they can rust over time and **** up
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    Haha no I didnt I did notice the top of the silver box ecu had condensation on it .im putting my floor heater in again today with carpet up so fingers crossed it dont stink after
    Jan 2011
    684
    Check out my post about 3 weeks ago. Also if your airbag light is on you can clear it with vcds lite, I had to on mine.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
  1. Water leak in rear of a4 avant
    By nickf in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2011, 10:14
  2. Water leaks
    By Vorshprungdork in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2004, 14:52
  3. Water Leak in the Cabin
    By bampy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2004, 18:00
  4. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
  5. Help, S4 water leak!
    By Futureman in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2003, 20:11
