Volks AutosEM Tuning
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    2.5 TDi Engine & Gearbox Mounts
    Just after some advice on the replacement of engine & gearbox mounts.
    My car is a 2.5 TDi Manual Quattro, over the past months when driving the drivetrain / engine feels a little spongy / loose.
    I can also rock the engine side to side by some extent.
    Im planning on replacing a few of the mounts - I know some are easier to replace than others, so im going to start with those.
    I have already purchased a front snub mount - and can fit that by putting the car into service-mode.
    How about the side engine mounts and gearbox mounts, are these difficult to swap?
    Thanks!
    Jul 2007
    London
    3,082
    You need to jack the car up or drop the subframe...i do it by jacking the engine up !
    FOR SALE:
    Sep 2013
    33
    yeah, undo the mount on one side completely the jack the engine up. Replace the mount and do the same on the other side.
    Lancaster
    1,637
    As above. You can change the snub mount without using the service mode.
    To do: None yet.
    glenandem's Avatar
    Sep 2012
    manchester
    457
    if your engine has similar mounts to my 1.9 tdi you can just basically jack both sides up carefully when youve undone the front snub mount,thats what i did, took about 20 mins each side although i did need to get the passsenger side slightly higher!
  1. engine and gearbox mounts???????
    By Big Bang Yam in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2013, 15:40
  2. Engine / Gearbox mount problem?
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2012, 10:40
  3. 2.5 v6 tdi engine mount swap
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 21:47
  4. 2.0 TDI engine mount failure
    By pioneer181 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 15:27
  5. Timing belt and engine / gearbox mount
    By nky_84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 21:57
