AH FabricationsEM Tuning
Results 1 to 14 of 14
    Mar 2008
    1,053
    Best way to fit coilovers without undoing the dreaded bolt
    Gonna fit the front coilovers on Saturday but don't want to undo the dreaded bolt ..last time I swoped the springs I took the hub nut off and the drive shaft and removed the hole unit but I found another way by undoing the top wish bone arms and removing the strut that way but witch is easyiest ????
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    Perservere amd take the pinch bolt out and replace it and copperslip it to make things easyer in the future, its not as hard to remove as evryone says, both of mine snapped and i had them both out in an hour with a punch and a hammer and some wd40
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    Mar 2008
    1,053
    Quote Originally Posted by Ollie-B View Post
    havent got time to do it that way ...
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,317
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    Dont copper slip the bolt. use grease the copper slip against the alluminium and steel of the bolt will help it corrode
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    2,159
    I use copper slip on my pinch bolts, but then again I change them every year when I service the car, takes a couple of minutes each side. only option is to remove the bolt on the bottom arm going into the subframe.
    Mar 2008
    1,053
    sure i said i havent got time to undo the bolt ..so why are people still telling me ???????????
    2,159
    I said undo the bolt on the bottom arm going into the subframe!!!!
    Feb 2013
    Wiltshire
    346
    Quote Originally Posted by vr6gordy View Post
    tbh if you dont have "time" to do the bolt, then I would strongly advise waiting until you do have time so you can do the job properly. If you do it wrong, it could have some serious consequences! Failing that, take it to a shop to get them to do it properly. Dont try and cut corners.
    Mar 2008
    1,053
    How will this let you drop the spring and strut out when it's still bolted to the up right ???
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    3 bolts under the bonnet, 1pinch bolt, 1bolt in the bottom of the strut
    Mar 2008
    1,053
    Was meaning the way b5nut said
    Stu-pid's Avatar
    May 2013
    80
    I fitted a set on a b5.5 passat without removing the pinch not sure if it the same process. But I compressed the spring in place and that gave me enough room to undo the top arms. It's awkward to get the strut out but saves messing about. There's a guide for it somewhere I just can't find it
    Stu-pid's Avatar
    May 2013
    80
    Mar 2008
    1,053
    What way won't work on a b6 cos there's only 1 bolt that holds the strut so you have to lower the hole unit
  1. Best way of fitting the lower VOTEX to my Audi Sport TDI bumper
    By Black_B6 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2013, 09:17
  2. the dreaded bolt
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2012, 21:16
  3. Carbon fibre DTM spoiler, any idea on best way to fit? Tigerseal or 3M tape?
    By Beni786 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th February 2012, 06:46
  4. the dreaded bolt on the suspenion a4 cab b6
    Last Post: 9th October 2011, 19:17
  5. Anyone know the best way to fit a water pump on s3 ??
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2010, 14:41
