Badger5AH Fabrications
Results 1 to 16 of 16
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,628
    Random warning dash symbols
    My A4 has displayed some several random warning lights. The other day is was a red symbol of an oil can, yet the oil level is perfect. It didn't stay on long.
    Today (during a heavy rain period) my wife had the chime and Brake warning symbol and an orange? Triangle flash up for a minute then go off.
    There was another last week but due to negotiating a roundabout I didn't get chance to view the symbol clearly before it went out.
    What would cause these random things?
    The brake pads and brake fluid are all fine....
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Dec 2006
    barnsley
    1,021
    common denominator is the dis system and clocks
    but its an unusual failure for them to go
    i would make sure first that the warnings youve had are not in fact genuine ...especially the red engine oil warning light
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    ESP light on the roundabout? Sounds plausible.
    Brake warning might be down to the pads?
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,355
    Sounds like something to do with wheels... well it doesn't but had the same symptoms on mine after putting some dodgy one's on, came on and off intermittently for a couple days then went away.
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    As you state heavy rain and going round a roundabout, perhaps you have water in the plenum chamber that's sloshing around???
    A4 Avant 1.9 TDi Sport GmbH
    S4_dan's Avatar
    Jan 2006
    1,628
    Quote Originally Posted by dualmono21 View Post
    Oil levels are fine, as it's new to me is the vehicle, I always keep a close eye on fluid levels for the first month or so, then check every 3/4 months.
    Pads are fine all round. Fronts are new and rear are about 50% worn. ESP is plausible but it was dry and I wasn't accelerating hard at all, no feeling of any wheel slip when setting off.
    Quote Originally Posted by DieselJake View Post
    Dodgy wheels? It has the standard '5 spoke' alloys on at the moment. Did you fit aftermarket/copies?
    Quote Originally Posted by Audi Doodah View Post
    No, the rain was only when the wife was driving, the roundabout was a dry day. The only time in the rain was with the wife driving.
    I'm wondering if maybe the ECU box or somewhere else is letting water in? Will have a look at the ECU box over the weekend. The carpets feel dry and we don't have any inside condensation issues to suggest damp inside but I could still be wrong.
    Is there any 'common' water ingress on the B6's?
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Oct 2009
    Hull
    1,442
    just because your oil level is ok dont rule it out!
    It could be a clogged strainer like the 1.8T suffers and could have been low oil pressure!
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by S4_dan View Post
    The pad light is orange I think, they can still give trouble if the wire is damaged or something. Low fluid level is a red light if I remember correctly.
    They tend to leak water around the ecu seal if it's damaged or disturbed, and if the drain plugs under the battery get blocked the plenum chamber will drip through on the passenger side.
    Dec 2006
    barnsley
    1,021
    yellow banner is low fluid ... red banner is oil pressure , something you most certainly cant check with a dipstick
    S4_dan's Avatar
    Jan 2006
    1,628
    Quote Originally Posted by stu_m View Post
    Does the 2.5 suffer with clogged strainers? It has FSH. I'm getting the timing belts done next month, will get them to service the car and check the strainer. It only happened once and has not done it since. Covered 200 miles since the light flashed up.
    It was definitely a red light that flashed up. Will check the ecu box and drain below the battery tomorrow.
    Was the red symbol, not yellow. Only came on for a second or two, then straight out. It happened as I put my foot down in second gear up a slight incline?
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,628
    An update, last night I popped to the local and had the car facing downhill on a steep gradient. Jumped back into the car after an hour, started it and left it idling whilst putting my belt on (foot on brake pedal, handbrake on) and I heard the 'beep', looked at the dash and my ABS, Traction control light was lit up on dash, and BRAKE! in RED on the DIS flashing.
    I didn't drive/move it. Pumped brake pedal a few times and no difference in feel.
    Turned off and restarted the car, no faults returned. Tried to replicate it today at work, but no joy. However, no rain since it did last night, however, it was raining before I went to the local!
    So i'm leaning more and more to water ingress somewhere playing havoc?
    I have ordered a licence for VCDS Lite......should get my email back on Monday hopefully so I can scan the car properly. My EOBD tool scanned it but couldn't make out any of the faults, but one was ABS ecu memory error or something? Will wait for vcds to confirm.
    Dan
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,628
    Unhappy DTC's
    Ok, I've done another scan with vcds-lite (UNREGISTERED I might add) and got these: (I did Engine, Brakes and Instrument modules)
    Engine
    Saturday, 05 October 2013, 16:14:07.
    VCDS-Lite Version: Release 1.2
    Control Module Part Number: 8E0 907 401 D
    Component and/or Version: 2.5L V6 TDI G000SG 0009
    Software Coding: 02015
    Work Shop Code: WSC 63351
    VCID: 263F759BD1FF
    Additional Info: 00005059 130 106LC150_1.V79450931286
    4 Faults Found:
    00523 - Intake Air Temp Sensor (G42)
    30-10 - Open or Short to Plus - Intermittent IS this part of the MAF or seperate sensor?
    00553 - Shareware Version. To Decode all DTCs
    31-00 - Please Register/Activate Couldn't find out exactly what this code relates to
    18057 - Shareware Version. To Decode all DTCs
    P1649 - 35-10 - Please Register/Activate - Intermittent Data Bus and ABS Module related!
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-10 - - - Intermittent CTS problem? Temp does take a wee while to get up to 90, but it does get there.
    And Brakes.....
    Saturday, 05 October 2013, 16:14:35.
    Control Module Part Number: 8E0 614 517 A
    Component and/or Version: ABS/ESP allrad 1726
    Software Coding: 04455
    Work Shop Code: WSC 00011
    VCID: 263F759BD1FF
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - - Obviously not a good fault!!!!!
    Finally Instrument!
    Saturday, 05 October 2013, 16:15:57.
    Control Module Part Number: 8E0 920 950 JX
    Component and/or Version: KOMBI+WEGFAHRS. RB4 D38
    Software Coding: 01400
    Work Shop Code: WSC 00001
    VCID: 88639B23****
    Additional Info: WAUZZZ8E83A11**** AUZ6Z0B017****
    2 Faults Found:
    01176 - Key
    07-10 - Signal too Low - Intermittent Not sure, maybe flat battery in key fob once?
    01316 - Shareware Version. To Decode all DTCs
    49-10 - Please Register/Activate - Intermittent ABS module no signal/communication
    It is possible that the ABS had been unplugged and car started at some point and codes not cleared? I have cleared all of the codes, and we are going out for tea so will scan car again tomorrow to see what/if has returned.
    I'm beginning to think I've bought a Lemon! :-(
    Dan
    2002 2.5 V6 Quattro
    Dec 2006
    barnsley
    1,021
    best thing to do is see if anyone close to you who has a full version can scan the car for you
    look on the vcds map on here
    Oct 2009
    Hull
    1,442
    any engine can suffer with it if the strainer is blocked!
    one thing that does stand out to me is the Internal Control Module Memory Error fault you get this sometimes with a duff battery which causes the brake warning to come on while cranking
    not sure why yours would do it after running though might just be a coincidence
    S4_dan's Avatar
    Jan 2006
    1,628
    Got my VCDS registered just now. My activation came through email at 5pm. Will scan tomorrow.
    I do have my reservations about the condition of the battery on the car. It does't struggle to start but I've noticed the voltage is never brilliant on it unless the car is running.
    Dan
    2002 2.5 V6 Quattro
    Dec 2006
    barnsley
    1,021
    If you now have the full version
    Scan the car and list the faults
  1. Unknow Dash Warning Symbol
    By thegrouch in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2013, 10:23
  2. Dash warning symbol?
    By lordjoe1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2011, 21:04
  3. Random warnings on the dash?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2009, 20:33
  4. engine management warning symbol lit?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2004, 16:07
  5. Air Bag warning on Dash
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 22:19
