EM TuningJMB Retrofits
    dares_uk's Avatar
    Dec 2008
    117
    Audi 1.8T Quattro Cab, 1st gear/Turning/Pulling away noise/rumble ?
    Hi
    I have had my new audi a few weeks now.
    Its an 1.8T Quattro cab.
    and these is something thats been niggling me,
    never had anything like thi son my Audi S3.
    Its been in the garage and had the front sus/sterring looking at.
    but having driven it a bit more i think i have narrowed down the noise.
    When i pull away, in 1st gear and i am turning, i get a rumbling noise from the back, either the wheels or something,
    maybe 2, maybe 3 times rumbles.
    Any ideas what this is ?
    thanks
    Mar 2011
    Truro, Cornwall
    62
    It's the quattro system. Mine does it too, also a 1.8t. Some say it's normal but I've read stories on changing the diff oil helps. It has been talked about a few times. Do a search on here and Google see what you come up with.
    I'm sure mine is getting slightly worse with time tho. Been meaning to chance the oil for a while now too.
    Nov 2013
    Walsall
    Hi guys,
    I've also noticed the same problem. I've just had a full major service done and the noise has slightly improved, it's like a 2-3 small rumbles pulling in 1st and 2nd and when turning. I am quite worried about this noise. Have you guys had the oil changed and has it helped/cured the problem?
  1. Audi A3 2.0 TDI (140) 1st gear?
    By mikeyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2011, 13:08
  2. Help! A3 Quattro, cant select gears, wont start/turn over.
    By PJM_01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2011, 12:05
  3. S3 1st gear problem and strange noise....
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2011, 22:07
  4. Audi A4 1996 TDI 1st gear problem :( Help !!!!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 22:15
