Sky InsuranceChris Nott
Results 1 to 13 of 13
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    565
    juddering on tickover......!
    My A4 TDI Avant has developed a judder on tickover,noticed it while sat at traffic lights,out of gear just idling then start a judder.
    Any ideas?
    munchkincoupe's Avatar
    Aug 2010
    971
    Flywheel?
    pauldazzle's Avatar
    Cardiff
    549
    DMF or engine mounts would be the most likely suspects. If it stops when you dip the clutch it's the DMF at fault.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    565
    no,it judders whether clutch pedal up or down but not all the timeno big deal just annoying when it shakes...
    pauldazzle's Avatar
    Cardiff
    549
    Sounds like it's probably an engine mount failing then. A scan with VCDS should show it up.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    D T's ?
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    565
    Quote Originally Posted by pauldazzle View Post
    that sounds better than DMF
    D T's ?
    D T'S Bez???
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    120
    Mine was doing same Steev it was dmf,
    fitted new clutch and converted it to solid flywheel last year and its much smoother now...
    B5 Avant 2.5 tdi 2000 X reg , Jaspis green, carbon vinyl roof and door pillars, remapped, fmic, 18" bbs lm rims, custom exhaust, coilovers, RS4 front bumper and grill, tints allround, pillar mounted boost/oil pressure guages, solid flywheel conversion.....
    pauldazzle's Avatar
    Cardiff
    549
    My engine used to randomly judder at idle & fitting a new engine mounting stopped it. i've had DMF failure on a couple of VAG cars & both times the juddering at idle would stop on engaging the clutch.
    Another way of checking the DMF is to hold the revs at 40ish mph in 3rd gear, & if the car surges your DMF is probably goosed.
    Stu-pid's Avatar
    May 2013
    75
    Mine had a shake on tickover. Had the timing belt and water pump done today. The mechanic said the water pump pulley was moving all over the shake has now gone and is running smoother. Just another idea for you
    Sep 2009
    Rumburgh Suffolk
    175
    Mines done this for the last 40K or so since I've had it, does it mainly when the engine is up to temp, clutch up or down makes no difference, no rattling or flywheel noise, and there are no engine mounting faults logged.
    Load the engine with A/C, demisters & lights etc and it stops shaking, or pick the revs up a little. Don't know what the culprit is..
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Sep 2009
    Rumburgh Suffolk
    175
    Paul, which engine mount cured it?
    Mark
    Mar 2013
    Southampton
    125
    I have what I describe as a shuddering on tick over, though mine can be accompanied by white smoke, if you raise the idle even very slightly, or a change in load on the electrical system it disappears, though it hasn't be fixed yet it has been diagnosed with several faulty diesel injectors, and was a well documented fault, it might be worth checking out.
  1. Juddering Tickover..................
    By robjsinc in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2009, 11:09
  2. clicking noise on tickover
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 18:22
  3. Judder
    By jdp1962 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2003, 15:06
  4. NOT STARTING ON THE BUTTON AND BRAKE JUDDER
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2003, 10:45
  5. Steering Judder
    By Drystone in forum Other Brands & Models
    Last Post: 6th January 2003, 17:28
