Results 1 to 9 of 9
    Jun 2013
    54
    help needed with lights please
    my headlight switch has recently gone faulty. the headlights main beam is always on. i cant switch it off for love nor money. also none of the fogs etc come on. i ordered a new one off ebay. all looks the same. however ive plugged it all in. still the same.
    is there anything like a relay somewhere that could of blown when the switch went?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Car Model, Original switch part number, replacement switch part number?
    Then can likely advise where to look.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Jun 2013
    54
    Ok I'll get the part numbers in a bit. Car model is a4 tdi sport 53 plate avant. Has front and rear fogs etc.
    thanks.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,344
    Sounds like the switch isn't the issue if it's still the same
    This video was crazy useful for me but guessing you don't need it
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    is the new unit the same part number inc the end letter ?
    is it oem or a chinese copy (as there known not to work
    if thats all good them its your central electrics module (located under the dash above your right knee
    remove open up and check for water damage
    Jun 2013
    54
    I've checked the part numbers and they are the same. The lights come on as soon as you start the car. Also the high beam flasher only flashes, you can't keep it on.
    Is there anything else it could be before I buy a new control module?
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    As requested - What is the part number of the original switch so I can determine if you are Hi-Line or Lo-Line circuit spec.
    This will reveal how the car is wired as there are a set of circuits for each.
    At least we have established the replacement switch is the same as the original.
    bez101's Avatar
    Jul 2008
    8,510
    and is it a copy switch you got or oem ?
    Jun 2013
    54
    hi sorry for late reply . the original switch number is : 8E0 941 531 A 01A- K2803 BK7 .
  1. facelift front end fitted help needed with getting lights up and running
    By 1750bulldog in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2011, 17:06
  2. urgent help needed with my 2007 audi s3 please!!!
    By s3r4pid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2010, 18:30
  3. urgent help needed with my 2007 audi s3 please!!!
    Last Post: 14th December 2010, 10:09
  4. HELP NEEDED WITH THIS PLEASE EVERYONE ?????
    By doug.p in forum In-Car Entertainment
    Last Post: 16th August 2010, 14:24
  5. Help Needed with my A4, please...
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th February 2010, 14:08
