Chris NottBadger5
    Sep 2005
    Staffordshire, UK
    455
    Intercooler Pipe Corroded
    Hi,
    Has anyone else got a similiar issue - or had one - done a search but couldn't find anything.
    When looking down the front of the engine - between the airbox/engine/radiator there is a T-Piece which I believe are Intercooler pipe.
    One part of it is metal and mine is terribly corroded....looking at replacing it looks a RIGHT pig, as the pipe is welded on to the mainframe I think...
    anyone else had to replace this or got one corroding?
    What would be the impact if there was air getting in at this point?
    Rich
    Audi Avant A4 54 1.9Tdi Quattro & Leon Cupra R 2005 1.8T remapped to 275bhp
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    Id imagine if you had a hole in the intercooler pipe work then youd notice a distinct performance reduction and youd probably here a fair bit of high pitched noise when pushing it hard.
    When I had a FMIC running on my Punto GT one of the jubilee clips wasnt quite tight enough and it whistled and drove like a dog.
    Sep 2005
    Staffordshire, UK
    455
    Hmmm no problem with performance but have ALWAYS had a bad starting issue with quite a bit of smoke and it smokes heavily on take off - but it is remapped.
    Just wandered if anyone else was experiencing a problem with the pipes down by the left hand side of the engine being corroded at all.
    Rich
  1. RS4 b5 intercoolers pipes
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2009, 00:16
  2. TDi Alloy intercooler pipe (behind driver side wheel)
    By sprout99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2008, 07:49
  3. Intercooler pipes?
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2008, 16:12
  4. Replies: 0
    Last Post: 20th November 2006, 18:49
  5. S3 trubo>intercooler pipe fiot A3?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 15:09
