Dead spot at about 2300 rpm
quattrov6tdi
cork ,ireland
I seem to have a hesitation about 2300/2500 rpm. I ran the vagcom and got this(i only posted the engine report if it's somewhere else,let me know). Now a couple of years ago I seemed to have a similar issue and the main stealer charged me 850 euro to replace an injector and timing belt.
4 Faults Found:
01441 - Low Fuel Level Sensor (G210)
30-10 - Open or Short to Plus - Intermittent
27-10 - Implausible Signal - Intermittent
01375 - Valves for Engine Mounting; Stage 1
38-10 - Output won't Switch or Short to Plus - Intermittent
00575 - Intake Manifold Pressure
08-10 - Control Limit Surpassed - Intermittent
Readiness: N/A
You have an overboost and the car is cutting fueling ! If it still pulls after the 2300rpm's hesitation then it's the turbo VNT mechanism sticking and it needs a good clean or a high speed motorway or italian tune-up !
Reactions: quattrov6tdi
I
958
