AH FabricationsSky Insurance
Results 1 to 10 of 10
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    aghh! fuel filter clamp leaking. help!
    OK, so I just changed my oil and filter, then spark plugs and moved on to the fuel filter. I haven't done it in the 5 years or so that I've owned the car so I figured it's due. I took a look at a couple of DIY threads on other forums and set to work. But have fallen down fairly quickly. These threads seem to indicate a pair of needle nose pliers should be used to squeeze the clamp and then pull off. WellI squeezed in various positions but felt no give. And with minimal movement during the process there is a now a drip coming from that connection. I've tried pushing it back on and taking it off completely but can't get it to move either way.
    Does anyone have any advice for a silly ******* on a chilly Finnish Autumn night?
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    glenandem's Avatar
    Sep 2012
    manchester
    529
    never done an audi one but done plenty of peugeots that look similar to rhat pic where they have a little plastic tap that you squeeze in and pull the hose off,ive had them too getting sticky and i found wrestling back and forward while carefuly squeezing they eventually give with a bit of force but you do have to be carefull with them being plastic!
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    I definitely don't have these clamps
    DIY: B6 A4 - Fuel Filter Replacement
    Looks more like this but doesn't seem to compress when squeezing and so I can't really get it off. :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by glenandem View Post
    Thanks mate. I've been back and forward trying again and again but think I will go out yet again for another try. what is it they say about people who try the same thing over and over but expect a different result?
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    nope. still fekked
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    second pic here suggests I was doing the right thing but the f cker just wouldn't unclip. It's probably b ggered now
    Audi B6/B7 S4 DIY: Fuel Filter
    Feb 2013
    Wiltshire
    346
    Quite an easy job. Get some pliers (or mole-grips) and squeeze the connector carefully. That will unlock it. Use a decent flat head screw driver and leaver the connector off. Be careful, but dont worry too much as its quite strong. Once one is off, you will realise how easy it really is and hte other one will come off quicker. There will be a crap load of fuel in teh filter, so keep a bowl or catch can of some sort underneath. Your arms will also get covered!
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    thanks for the input mate. that's definitely the technique I was applying but with the needle nose pliers squeezed and the first attempt to then move it backwards it jammed and started dripping. i'm off to the shop in a moment to see if I can get a repair kit because if I continue as I am there's a good chance that clamp will be knackered. (sigh)
    By the way this forum is full of people finding "easy" jobs difficult ;P
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    ordered a new clamp at the local dealer, went home and investigated further. back clamp came off easily (same way I tried the front but this time it worked). After it was off I could move the filter around a lot easier and found that the plastic casing of the front clamp was cracked at the other side (opposite side from that seen in my photo) and seems to have been that way for a while. The missing torx screws on the plastic cover suggest that maybe someone has been in there once upon a time before me. Or maybe I cracked it myself. But whatever the case one came off easily and the other didn't. At least I don't have the buy the full hose or I'd need to lift the back seat and swap the hose from the fuel pump end too.
    Feb 2013
    Wiltshire
    346
    yeah, the back one (I think thats the oneyour having issues with) was a dog in comparison to the front clip. Dont use nose pliers, use mole grip. more even and flatter compression. Its the top of the clip that "sinks" in to release everything. The lip on the filter is quite high so is a bit more difficult to remove. its probably leaking as not fully seated back in. The filter has a long reach into the clip.
  1. Fuel Filter clamp issue
    By Tsportaudia3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2012, 21:59
  2. Fuel Filter 2.0 TDI.. Help please?
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2010, 21:25
  3. Help asap. Fuel filter!
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2010, 21:28
  4. V6 Drain Diesel Fuel Filter - Help
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2008, 21:58
  5. need help fuel filter
    By audi-90qua in forum General Technical / How To
    Last Post: 27th October 2007, 23:03
