AH FabricationsVolks Autos
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By adamss24
Thread: 2.5 TDI Bad Misfire AKE Engine Code
    Feb 2011
    Ireland
    34
    2.5tdi Developed a severe misfire and almost complete power loss. Cruising along 70mph on motorway after 100 mile round trip and misfire began without warning. Limped home and found 2 fault codes;
    01268 Quantity Adjuster (N146) Defect Intermittent
    17583 Pre injection turned off P1175
    No water in fuel or anything obvious. Think maybe injection pump may be on the way out. Any thoughts on any other checks I could do would be appreciated before I take the pump off and send away for testing.
    Oct 2012
    385
    Dare i even mention camshaft wear
    Jul 2007
    London
    3,070
    faulty pump, i am surprised it's still running ! last one i worked with this faults did not start anymore...
    abyrne153 likes this.
    FOR SALE:
    Feb 2011
    Ireland
    34
    Thought as much Chris. Thanks again for your help. Just didn't want to take the pump off if there was anything else to try. It is starting and ticking over a bit lumpy but it is driving like a complete pig.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    if i remeber rightly its the pumps ECU that is at fault and can be re programed,
    Feb 2011
    Ireland
    34
    Thanks Turkster. You are right. The ecu on these pumps are a generally the source of the trouble. The soldered joints on the pcb break due to heat / cool cycling and this one has been repaired before. I took the cheap route a few years ago and sent just the ecu off for repair and although the car ran ok afterwards it was never perfect. It was smoky on startup when cold and the fumes were very strong on tick over. The pump should have been taken off and sent away to be calibrated/tested but I just never got around to getting it done. This time the pump is coming off and I am getting it done properly.
    Feb 2011
    Ireland
    34
    I checked the cams a short time ago and they are in good condition.
  1. A4 B7 3.0 TDI Retrofit Tow Hitch – Engine Coding
    By 3.0 TDI Paul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th May 2013, 11:07
  2. 2001 Allroad 2.5 TDI AKE engine code
    By danny_acs in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st November 2011, 08:31
  3. A4 2.5 TDI engine code AKE camshaft replacement help please
    By doc2000ad in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2010, 04:06
  4. Audi TT 2.0 16v TDI engine code?
    By EMT in forum TT/TT-S/TT-RS Forum
    Last Post: 6th May 2009, 13:52
  5. 1.9 tdi (115) - whats the engine code
    By mystic.bertie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2009, 19:18
