AH FabricationsBadger5
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By quattrojames
  • 1 Post By desertstorm
Thread: 15" rims on 3.0l quattro????
    morrisonbrink's Avatar
    Looking at winter tyre possibilities for my newly acquired A4 cab 3.0l Quattro, the sticker on my car seems to suggest 15" winter wheels ????? Hard to believe they would clear the brakes?
    Has anyone else come across this? How does the car handle on such radically different rubber?
    Obviously there are lots of other wheel and tyre combinations that will fit, but that might give me an insurance problem where I live (France).
    This is the car-
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    That might be a generic sticker? Do you know what size your front discs are?
    16" wheels will clear 312mm front discs ok.
    Not sure about brake disc but 312mm seems likely ( bit late to be removing wheels). Just checked the space saver spare and it is 17" so 15" looks even less likely to fit.
    It seems unbelievable that they would put a "generic" sticker on to a car that quotes an impossible size for such a vital part though?
    Is it possible to get a new sticker from Audi?
    Mar 2008
    Dorset
    13,856
    You can get different stickers depending on factory fitted wheel sizes, I agree it seems unlikely they've fitted the wrong sticker though. People sometimes change the sticker when they upgrade to 18" wheels as no A4 left the factory with 18's (unless specced as an extra/or an S4) prior to the S-Line in 2004. In saloon/avant guise at least.
    I would expect a 3.0 to have 312mm discs, but Audi do some funny things, and I have no idea on Cabby specs.
    morrisonbrink likes this.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,353
    Smaller and narrower tyres have better grip and performance in snow or ice because the smaller tyre cuts through snow more effectively due to the weight of the car pressing on a more focused set of contact patches. Smaller is also better for acceleration and mpg plus tyre prices are cheap as chips.
    Could measure the size of the discs before fitting smaller alloys, if they don't fit width ways use spacers.
    Quote Originally Posted by DieselJake View Post
    I understand all that, it would be handy to be able to fit 15" rims, but I doubt they would fit over the brakes. Which leaves me with the insurance problem caused by the wrong sticker The sticker and the spare do not correspond either.........
    Oct 2012
    434
    You would better off fitting 16 inch audi rims from an SE or early Sport model then tyre size should be 205/55/16 they should fit, i have a set for our sline q avantand they fit fine. you might also want to check rolling radius as well so it doesnt unduly affect the speedo reading
    So, as I do indeed have 312mm brakes in the front, I ended up getting some cheap second hand 18" old RS6 style Ronals. I shelled out for a set of nokian WR A3 s in the same 235 40 R18 size as the summer tyres to keep the insurance happy. The wheels are 7.5" off an A3 so would benefit from spacers to fill out the arches a bit better, but no hurry. Tyres seem very good so far.
    Once I had got the summer set of wheels off and cleaned some of the grime off, it became apparent that one of them is a bit bent, which would explain the slight vibrations at motorway speed. Lots of weights on it to try and compensate, but perhaps it would benefit from being straightened? Anybody have any experience with wheel straightening? Is it worth doing on this-
    The wheel is perfectly airtight and the vibrations are minor, is it worth paying for straightening?
    Nov 2013
    Heath Hayes
    951
    A bit bent is an understatement that is so obvious it really needs replacing. It's likely to have fractures in the alloy and although it's not leaking another pothole at some point in the future and it will be.
    BakPak likes this.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    You can get the wheel sorted and usually costs about £50.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
  1. How much did you get quoted for a 1.8t quattro exhaust ?
    By Jasdent in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2011, 20:55
  2. Rims for B5 A4 Quattro
    By bandy97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2010, 00:31
  3. Replies: 9
    Last Post: 23rd March 2009, 10:18
  4. Quattro GmbH rims
    By nickclements in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th May 2004, 13:39
  5. Rims for 2000 audi 1.8t quattro
    By justinr66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2004, 10:10
