Badger5Monster Motorsport
Results 1 to 8 of 8
    Apr 2013
    6
    TDI 130 A4 Singlemass flywheel and gearbox failures?
    been pointed over here for info on my derv burner by niki at R-Tech. Ive heard a few times that switching to a single mass on the 1.9tdi 5 speed a4 can rip the syncros to pieces? How many people have actually had this happen? i dont mind extra chatter at idle and take off but looking for something to take a little more power than the stock dual mass. mine is about 5k old and the clutch holds great but i get dual mass shudder at the mo and it will probably get worse as the car has a map on. Looking for genuine issues not my friends friends dogs cars gearbox fell to pieces afterwards lol
    thanks in advance
    May 2012
    RETFORD, NOTTS
    1,753
    I am losing fourth gear on my A3 6 speed 130 tdi with single mass if thats any help. 40k miles on the clutch, 100ish on the car. Fourth is hard to go in for some reason unless i push down on the stick almost like the reverse down to get into 4th if that makes sense. No crunching and no other noises, so not fussed atm as it could be a sloppy cable or bush.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Apr 2013
    6
    Cheers, I was told it was specific to the 5 speed in the a4.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    single mass on a 5 speed 01a box here, apart from pre existing sticky 2nd it's the same as it always was with extra power added
    Apr 2013
    6
    Excellent, what single mass setup are you using?
    Aug 2012
    Darlington
    172
    I haven't done the conversion on my 5spd A4 but have on my 5spd Golf using the Valeo kit that the mechanic said used a new type of spring loaded clutch to compensate for the removal of the dual mass system. The Golf is smoother than it has ever been with this clutch and SMF fitted
    Apr 2013
    6
    found the valeo kit listed, but unsure if it comes with a clutch and what its rated too, for obvious reasons i dont want it to handle less torque than my current one
    Dec 2006
    barnsley
    1,020
    a lot of the new valeo single mass kits come with an extra long throw to compensate for the removal of the dual mass
    i have one fitted to my seat leon and its lovely and smooth
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
  1. Audi A4 1.9 tdi 130 S ECON light and temp gauge problem
    By dean2013 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2013, 21:37
  2. Replies: 0
    Last Post: 23rd February 2013, 14:31
  3. Looking at B6 A4 TDi 130 Avant - found one and would like advice
    By sparco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2011, 21:45
  4. 1.9 tdi 130 dual mass flywheel and clutch kit - how much ????
    By blucoop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2010, 17:44
  5. Clutch replacement on TDi 130 - dual mass flywheel as well?
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2008, 20:44
