AH FabricationsVolks Autos
Results 1 to 7 of 7
    Jan 2011
    682
    Flooded cabriolet ! Rear window glue fix ?
    Hi everyone,
    Well it finally happened ! I got Cab full of water. I think it was coming from the ECU seal, so I stripped it all out, cleaned it, put it back with seal and a little bead of clear silicone for good measure.
    In the process I took the sill trim off and the drivers seat out to I could get under the carpet on the drivers front and rear.... disaster ! Soaking wet, and I mean wet, never seen so much water in a car.... so its currently on the drive and getting dry. The soundprofing is very very good and now I know why, its over 2 inches thick in places which also makes it a very good sponge !
    BUT thats not the worst of my problems, when I took the rear bench seat out there was a little bit of damp... turns out my roof rear window bonding / glue has failed on both sides for several inches ! So all in all not a good day !
    I actually have a brand new black outer roof canvas in my loft that I got on EBAY for £150 a couple of years ago but ita alot of work to fit and Im hoping a temp fix with silicone will do for now !
    Any advice would be appreciated though.
    One thing about these kind of jobs you do see how well Audi build cars, all cars have faults but the general buuld quality, the electrical wiring, the connectors etc is all way better than Ford or Renault...
    Check out the pics and especially the video of all the water in the rear carpet lol !
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    Ouch.
    I'm still getting a small amount of water in my ECU.. I'll have to strip back as well.
    I'm going out to check mine over now, just in case.
    I hope you get it all dried out and back to normal quickly.
    My friend had a Vauxhall Omega that got flooded.. He had to drive about with the rear carpet lifted up on ice cream tubs for weeks after, before he got all the moisture out.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Jan 2011
    682
    Cheers, yeah the ECU does seem to be a common place for leaks. I think mine was the seal between the ECU housing tray and the body of the car and not the ECU cover lid, the actual ECU is dry as a bone.
    Its all dried out now, everything is back in, cleared the airbag light and job done hopefully. Time will tell if my silicone holds out on the rear window ! Im guessing it wont last !
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,465
    did you check under the battery ?
    Jan 2011
    682
    Sure did, nothing much there, the gromet under the master servo is removed anyway but there isnt any water there.
    Oct 2005
    bristol, uk
    757
    Did you find the source issue?
    Researching and potentially looking for a nice S4 B6
    Previous cars: Modded Toyota Celica 1.8 Vvtli, modded mk1 TT, standard mkv r32 dsg
    Current: family wagon diesel
    Jan 2011
    682
    Pretty sure it was the ECU seal but as my window on the roof had unbounded there will be some getting in there as well. All seems ok now though thankfully.
  1. How do i remove A4 Cabriolet rear bumper??
    By whitty in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2010, 16:32
  2. Cabriolet rear seat removal
    By cold_guppy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th July 2010, 12:25
  3. How do I... put b7 cabriolet rear lights onto my b6 cabriolet
    By dhillon884 in forum General Technical / How To
    Last Post: 24th May 2009, 11:41
  4. Cabriolet rear bumper trim and wheel offsets!
    By markyzs180 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 23:15
  5. A3 cabriolet rear lights - Picture request
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2008, 09:31
