Chris NottMonster Motorsport
    Aug 2012
    Darlington
    172
    Strange rhythmic clunking/vibration
    1.9 130. The car has been running absolutely fine until yesterday morning. When I started it up there was a strange vibration through the car, a rhythmic clunking and a rough idle. I didn't have time to look at it so left it until today.
    I checked the fluid levels which are fine. Fired it up. It now idles fine. I took it for a short drive and it drives fine. The clunking noise seems to match with the item boxed in yellow moving from side to side. Could just be a coincidence as I'm not that knowledgeable on engines and don't know what it is or whether it is supposed to be moving or not. Any ideas
    glenandem's Avatar
    Sep 2012
    manchester
    528
    Do a search for alternator clutch pulley, if your tensioner is bouncing about will probably be that!
    Aug 2012
    Darlington
    172
    Thanks for that, I'll have a look about
    Aug 2012
    Darlington
    172
    A quick look around on here and watch of vids, etc, shows that this is exactly what it is. Thanks for the heads up
    glenandem's Avatar
    Sep 2012
    manchester
    528
    No probs, I did one on a passat a few years ago and the alternator is easy to get out but think you needed a multi splined socket if I remember right on the actual pulley!
    Oct 2012
    429
    You do and they are usually on f****n tight
  1. Clunks, now vibration, quattro issues?
    By BigAardvaark in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2011, 11:49
  2. Engine vibrating strangely while idling???
    By skol in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 07:36
  3. Strange grinding/vibrating noise from rear wheels when turning!!??
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2010, 11:38
  4. Strange shaking/vibration/juddering from front wheel/s
    By Dazmo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th March 2010, 22:47
  5. Strange engine vibration....
    By rusty1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2009, 17:50
